Oil live meter on 2015 JKU - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Oil live meter on 2015 JKU
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Win a free set of 35" or 37" tires from Zone OffZone Offroad - Jeep Forum Promotion
Unread 05-20-2015, 06:56 AM   #1
jeepwrnglr92
2015 JK Wrangler
Oil life meter on 2015 JKU
I have 5K or so on my Jeep I did the oil at 1K when I got it. So 4 K or so on this oil change.
I check the oil physically and all looks OK.
Oil life meter says 55% used.
Does this meter to any testing or is it programed for like 10K?
I am thinking I am 1K over my usual limits. Not a big deal all highway miles.
Just wondering about the meter and oil life.
I think I need to get it changed sooner than later.
Any info on the oil life meter would be appreciated.
I am not running synthetic as far as I know it's what ever the dlr uses.
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 07:11 AM   #2
LIJeepJC
Did you reset it after the oil change? I believe it needs to be reset after each change.
LIJeepJC is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 07:11 AM   #3
bogleparsons
In the owners manual it states that an algorithm is used to determine oil life. Such things as cycles, rpm's and such are used within the algorithm to give you the displayed value.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 07:26 AM   #4
jeepwrnglr92
2015 JK Wrangler
Yes It was reset by the dlr.
Thx on the manual stuff. I dont have my handy just now.
so the question is should I let it go longer since it says 55% used at 4K miles or get it changed. I usually do my non synthetic cars at 3500 miles but synthetic i run 5 or 6k miles.
I have not swapped this one to synthetic yet as I have 4 oil changes with the dlr and have to research what oil I can use in this engine. I like Mobile 1 for my GM cars.
Unread 05-20-2015, 09:35 AM   #5
Godholio
You can't tell the condition of oil by looking at it, unless there's something REALLY wrong. Color isn't an indication of purity or condition.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 09:44 AM   #6
duneslider
I have been curious about how good these indicators are. I don't have this on my jk but on my commander I do and I use synthetic oil and without fail the indicator comes on WAY early, sometimes even before 3000 miles. I am told this one is using the algorithm and not mileage based but surely synthetic is good for more than 3000 miles. Mine doesn't have a % indicator, just the note comes up its time for oil change.
duneslider is online now   Reply With Quote Quick reply to this message
Unread 05-20-2015, 10:42 AM   #7
jeepwrnglr92
2015 JK Wrangler
Well i disagree on that. My oil only looks slightly brown vs the original clearish color is is when new. Does not smell burnt (I would hope not on anew jeep)
If it was bad it would be dark brow or black etc.
Now with that said there is no way of know about suspended matter in the oil but one hopes the filter is doing its job.
I'll probably just get it changed in the next week or so when the DLR can get me in.
Unread 05-20-2015, 11:12 AM   #8
bogleparsons
I just let mine get down to under 10% life then change it. I also use full synthetic.
If it makes you feel better than change it at 5k, but I went to 8k last change.
My Manuel says not more than 10k between changes.
Unread 05-20-2015, 11:55 AM   #9
jeepwrnglr92
2015 JK Wrangler
Yes if I was running full synthetic I would leave it be.
What synthetic do you use in it?
Unread 05-20-2015, 03:50 PM   #10
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I typically go to at least 75% life on all my metered vehicles....
Not necessarily true! A high detergent oil will carbon color faster than a low detergent oil... and I have personally changed the wiped mains on a Chrysler 360 after sludge plugged the head drain downs and the pump starved. The oil came out nice and amber - all the color was stuck as sludge in the head rather than mixed with oil!
J Wm Bishop EA, ASADE
My greatest fear, is that when I die, my wife will sell my Jeep for what I have told her it's cost ...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 04:01 PM   #11
arbakken
Go pull the oil out of a 6.5 GM diesel after 30 seconds of running and it is jet black. I leave the synthetic oil in my Focus for 10k and it comes out a nice amber color. I'd trust the meter, the 'change every 3k' thing worked great in the 70's, but engines and even dino oil has evolved
arbakken is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 04:31 PM   #12
pentastarguy
i just change my syn oil and filter every 7000 miles. my meter has never informed me of needing a change.
pentastarguy is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 04:56 AM   #13
jeepwrnglr92
2015 JK Wrangler
Thx for all the good input.
I am old school so I amuse to the 3k or 3500 changes.
Not like I am gonna get it changed this weekend with the holiday and all.
Guess a another week or 2 wont hurt it.
