Oil Leak - Crankshaft Seal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Oil Leak - Crankshaft Seal
LOCKERS!!!! - ARB, Auburn, Detroit, Eaton, OX, Spartan, YuRIGID LED Light Blowout Sale - All Sizes, All Series, all ECGS Black Friday Sale!!
Unread 11-10-2014, 09:58 AM   #1
UTKJK
I've had a leak in my '07 JK since I got it 2 years ago.
It looses about a quart a month, so about a year ago we changed out the rear main seal. No luck, still leaks at about the same pace.
After further investigation, it looked to be the crankshaft seal (front seal). So we changed it. It gave us some issues, and we had to change about 2-3 times. But it's still leaking.
Question - Any tricks to getting the seal in without it leaking? We applied oil to the seal an lightly tapped it in with a screw driver. I've read some posts (not for JK's specifically) were a socket was used to push it back into place. Does anyone know what size sock can be used for a JK? Once the seal is in location, does anything else need to be done (e.g. RTV)?
UTKJK is offline   Reply With Quote Quick reply to this message
Unread 11-10-2014, 10:46 AM   #2
ronjenx
ronjenx's Avatar
Have you cleaned all oil residue off and look for it to come back, possibly from a source higher than the crankshaft?
2008 JKU Rubicon
42RLE Auto
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 11-10-2014, 10:58 AM   #3
JeepNewb
If you see it pooling by, and then dripping from your bell housing dust cover it could be the timing chain cover. There was a problem in the 07's with Chrysler using a porous timing chain cover material. It creates a leak that seems to pool by the bell housing. There is info on it if you search and in the TSB.
Had mine replaced earlier this year.
JEEPN' - 2007 Unlimited X (4.10's, LSD)
RIP - 2003 Nissan 350z / 1990 Pontiac Firebird 3.1
JeepNewb is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 03:37 PM   #4
UTKJK
Where do you buy a timing chain cover? Would an Advanced Auto or Auto Zone carry that or is that a dealership item?
Unread 11-12-2014, 04:07 PM   #5
jwmbishop
2011 JK Wrangler
link
J Wm Bishop EA, ASADE
Alcohol - because great stories never run on gasoline...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 07:42 PM   #6
Jiblet
Originally Posted by JeepNewb
If you see it pooling by, and then dripping from your bell housing dust cover it could be the timing chain cover. There was a problem in the 07's with Chrysler using a porous timing chain cover material. It creates a leak that seems to pool by the bell housing. There is info on it if you search and in the TSB. Had mine replaced earlier this year.
Here's the TSB
http://project-jk.com/images/tsb/TSB_09-008-07.pdf
Jiblet is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 09:40 PM   #7
NIUPonyBoy
subscribing as I am SURE I will need this later.
'13 Explorer, '12 Outback,'07 JK, '07 Mustang GT Convertible, '05 PowerWagon,'05 Freestar
NIUPonyBoy is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 02:44 PM   #8
UTKJK
We're going to try to change the seal again.
1. When setting the seal, how far back should we push it?
Can pushing it too far or far enough cause it to leak?
2. Anyone know the size of socket that you can use to push the seal in?
3. If it is the timing chain cover, where will I notice the leak coming from?
Right now I'm sure it's coming from the crankshaft seal, because the pulley is throwing it all over the place. And it wasn't doing that before I changed tht seal.
I actually found oil ONTOP of my hood. From the tracks, it looks like it was slung on the tire, which slung it on the tire fender, and the wind blew it up on the hood.
Unread 11-24-2014, 10:16 PM   #9
870
use a socket that is the same size as the metal ring of the seal. Spring always goes towards the oil.
870 is offline   Reply With Quote Quick reply to this message
