Oil leak - JeepForum.com
post #1 of 12 Old 05-21-2010, 04:40 PM Thread Starter
wdryan85
Oil leak
I have an oil leak coming from somewhere. Its not a bad leak but it did run dry once on me. Lately I've been just adding as needed. ( which is about 1 quart every few weeks.) Wondering if anyone has had this problem?
wdryan85 is offline
post #2 of 12 Old 05-21-2010, 05:09 PM
McKBrew
JK Wrangler
When is the last time you have had your oil changed and your filter checked. I had a small leak once that ended up being the filter not being on tight.
Best thing is to get everything topped off, check the filter and then park somewhere that you can look for signs of a leak.
McKBrew is offline
post #3 of 12 Old 05-21-2010, 05:20 PM
JIMBOX
Another guy had something penetrate the borttom of his oil filter and lost ALL HIS OIL, lost the engine, because of that--check your filter !!
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 12 Old 05-21-2010, 05:47 PM
1222
RIP John
1222's Avatar
If you’ve been leaking oil like that then you must have a lot of oil, dirt and grime on and around your engine. I would do like said in above posts but before that, I would get underneath your Jeep and spray with engine gunk and then hit it with high-pressure garden hose. Now you’ll have a better chance to see the leak.
(2011-2016)
1222 is offline
post #5 of 12 Old 05-21-2010, 06:00 PM
N2rock
N2rock's Avatar
how many miles in those few weeks are you talking about? It has been commonly noticed that these JK's tend to go thru a quart - 1.5 quart around 3000 miles. Since I get my oil changed every 3k, I don't pay much attention to mine. But people that go longer than 3k have noticed being low. Someone over on JKO even mentioned that According to Chrysler it's normal to burn 1qt of oil per 1k miles.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #6 of 12 Old 05-21-2010, 09:24 PM Thread Starter
wdryan85
Well I've checked before and its coming from just after the oil pan. Hoping its not a main seal.
wdryan85 is offline
post #7 of 12 Old 05-21-2010, 10:01 PM
1222
RIP John
1222's Avatar
Again, clean up the mess with engine gunk and a high pressure water hose. Then you’ll be able to actually see exactly where.
(2011-2016)
1222 is offline
post #8 of 12 Old 05-21-2010, 10:55 PM
kyjeep98
2010 JK Wrangler
That looks like alot of oil be sure to check it very often until you get it fixed.
kyjeep98 is offline
post #9 of 12 Old 05-21-2010, 10:55 PM
owenswj
Holy crap, thats alot of oil to be losing in a few weeks. Must be a major leak.
owenswj is offline
post #10 of 12 Old 05-22-2010, 09:38 AM
Tireguy
2009 JK Wrangler
Brake-clean (brake parts cleaner) in aerosol cans will clean oil/grease/dirt off instantly (and evaporates fairly quickly). But it goes fast...buy more than one can. Use a catch pan...what ever you clean off the engine will end up on your driveway.
Tireguy is offline
post #11 of 12 Old 05-22-2010, 10:16 AM Thread Starter
wdryan85
Thanks I'll try and clean it up and see exactly where it is and go from there. Try and take another pic as well. Thanks again.....
wdryan85 is offline
post #12 of 12 Old 05-23-2010, 04:58 PM
XWind
If its still under warranty the dealer should cover it. Mine had a really small leak and the dealer put some detergent type of dye in the oil and had me run it for about 300 miles. Turns out I had a bad gasket seal around the top of the engine on the intake manifold.
The bad part is that is was about a 4 hour fix that involved removing the top of the manifold to replace a simple gasket. Don't know if thats what you have but mine was leaking in the same area. I could see oil forming around the transmission housing - just not as much as in your picture.
Hope that helps.
XWind is offline
Pinhole leak in radiator--Alumaseal/Bar's Stop leak? JEEP97TJ TJ Wrangler Technical Forum 16 06-11-2010 07:01 PM
Stop leak for heater core leak?? alaksaboy YJ Wrangler Technical Forum 16 12-23-2009 12:59 PM
Engine oil leak! Front diff sweatl leak Mr.Unlimited JK Wrangler Technical Forum 11 09-22-2009 09:49 PM
Tranny Leak, any common place for a jeep to leak jb1dsl TJ Wrangler Technical Forum 6 03-23-2006 11:09 AM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 01:46 PM
