Oil Drain Plug Size for FRAM Sure Drain - JeepForum.com
post #1 of 13 Old 02-12-2009, 07:38 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Anyone know what size the oil drain plug is for JK 3.8L engine?
FRAM Sure Drain has these sizes I see.
12 mm x 1.25
14 mm X 1.5
15 mm x 1.5
18 mm x 1.5
1/2 x 20
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #2 of 13 Old 02-12-2009, 08:27 PM
trowand
2009 JK Wrangler
What on Earth is a Fram "Sure Drain"? A magnetized drain plug?
'09 Unlimited RUBICON in "Detonator Yellow". Old Man Emu 2" Light Duty lift. 305/70/17 (34"x12"), 1.5" wheel spacers, Bushwacker Flat Flares, three sets of 100+ watt IPF lights. Four wheelin' in the Jersey Pine Barrens!
trowand is offline
post #3 of 13 Old 02-12-2009, 08:37 PM
CGScotty
Straight And To The Point
CGScotty's Avatar
After a google search it appears there is some misunderstandings. Check out ebay and it gives you one that is for the 3.8 jeep but it doesn't seem very clear, then Jegs says no on all of them. I like the looks of it. I usually get oil everywhere when I change mine out.
ɟlǝsʇı ʇnɔ plnoʍ ʇı uǝɥʇ˙˙˙˙˙oɯǝ sɐʍ ssɐɹƃ ʎɯ ɥsıʍ ı
NRA Patron Member
CGScotty is offline
post #4 of 13 Old 02-12-2009, 08:39 PM Thread Starter
Thunderstrike
2009 JK Wrangler
It's the best thing when you have a Skid Row Engine Skid (any engine skid for that matter). Or, you'll have oil splash all over the skid and your garage floor.
Once you install this, to drain the oil, unscrew cap. Then you screw in the drain cap with a tube. As you screw this tubed cap in, the drain safety disengages allowing oil to flow down the tube (slowly) into your empty Mobile-1 gallon jug. No splash with the ultra thin 5W-20 weight oil. It makes your oil change at home chore a very simple one.
You should remove the plug completely every 3-4 oil change just to see if there's metal shavings to be drained out (I had none with my TJ with 76,000 miles).
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
post #5 of 13 Old 02-12-2009, 08:44 PM
CGScotty
CGScotty's Avatar
I will be getting one of these. Im just happy I have about 5000 miles before I have to worry about it.
NRA Patron Member
CGScotty is offline
post #6 of 13 Old 02-13-2009, 08:54 AM
firefly
I've mentioned it before - a manual oil pump does an excellent job for oil changes. No crawling under the car, no mess, and it allows you to first remove the old oil, then add the new oil and then pour the old oil into the empty oil container. Been using one for years on boat and other cars and it works great. Just insert tube into dipstick hole, pump 3 or 4 times and walk away. The suction empties your oil pan. You can also use it to change fluids in your diffs.
TJ Sahara (with Plow)
BMW 330xi (Sold!)
BMW X3
65 Vette ragtop
2008 JK Sahara Unlimited
firefly is offline
post #7 of 13 Old 02-13-2009, 01:03 PM
dsy
Is this what your looking for
http://www.quickoildrainvalve.com/Se...ts.asp?Cat=102
Flame red unlimited Rubicon 5 speed 5-45RFE Auto , 35" KM2's, RCV front axles, 3 1/2" AEV premium lift, AEV snorkel, LoD front bumper with Warn powerplant,Full River Raider Alum skids, Marchal E-Code Lamps, 45qt Engel refrigerator / freezer, 09 Mygig w/ipod interface, Katzkin leather, ya its got a Hemi :-)
dsy is offline
post #8 of 13 Old 02-13-2009, 04:06 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Originally Posted by dsy View Post
I think these are the Fumato valves, which I don't like. I prefer the FRAM Quick Drain. Thanks very much for providing the link, though.
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
post #9 of 13 Old 02-13-2009, 04:08 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Can someone post the oil drain plug size when you're changing oil?
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
post #10 of 13 Old 02-13-2009, 04:27 PM
dsy
That link also had the size listed 14mm X 1.5
dsy is offline
post #11 of 13 Old 02-13-2009, 05:14 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Got it. Thank you.
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
post #12 of 13 Old 02-25-2009, 05:00 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Went by a Jeep dealer to check on the oil drain plug -- JK has 14mm oil plug, so one needs to order a FRAM Sure Drain SD2.
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
post #13 of 13 Old 02-25-2009, 05:45 PM
JohnRodriguez
aeroquip now makes a quick drain plug for oil pans. It is like a air chuck fitting, very quick to attach. You can see them on summitracing.com. just type in oil drain plug and select aeroquip. i'm not sure if the 3.8 is a 12-20 thread or a M14-1.5, but ill find out next weekend when i change the oil. I had purchased both sizes.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
Fram Sure Drain size? garybattles TJ Wrangler Technical Forum 4 01-10-2009 03:39 PM
Oil drain plug size hoki06 YJ Wrangler Technical Forum 8 11-16-2008 07:03 PM
Drain Plug Size AX-15 Baetis99 YJ Wrangler Technical Forum 3 04-07-2005 04:31 PM
BA 10 drain plug size JeepCrz YJ Wrangler Technical Forum 3 02-08-2005 10:03 PM
What size is the drain plug on the AX-15? wyldejackyl TJ Wrangler Technical Forum 4 05-10-2004 12:27 PM
