I use a half-inch wrench - works fine. Seems pretty snug on there.
On a related note - given the ease and painlessness of getting the stock drain bolt out, I really can't imagine trusting some 3rd party valve jobbie to do the job. Seems like an unnecessary risk. I changed my oil (myself) over this past weekend and hell, I didn't even get any oil on my hands when taking off the drain valve...
sorry to be a ****.. but are yall that freaking lazy u cant take a simple nut out? come on.. if u cant do that.. go take it to someone to change ur oil..
works great if you have belly protection. you can attach a hose to this so you dont end up with oil everywhere when you pull the drain plug. size 14mm-1.5
I'll get a pic of it next to my stock plug. It's almost the same size hanging out of the pan. It hangs out a third of what a fumoto does. I bought the compact. If you have something that close to the oil pan, the plug is the last thing to worry about, something else is getting damaged first.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
