OEM TIPM Study - JeepForum.com
post #1 of 127 Old 04-23-2011, 03:31 PM Thread Starter
ronjenx
ronjenx's Avatar
OEM TIPM Study
The Totally Integrated Power Module (TIPM) is a lot more than the fuse box it appears to be. It is responsible for a lot of the power switching/modulation/distribution, and communications with other systems in the JK electrical system.
New TIPMs go for $200 - $250. Used can be found for $0 - $200; very negotiable. After replacing the TIPM, it may need to be programmed to the vehicle. As far as I know, only the dealer can do the programming.
This is from the factory service manual:
The original Cab Compartment Node and Powertrain Control Module must be installed and functioning properly prior to powering up the new TIPM. The TIPM receives vehicle configuration data from the CCN and Vehicle Identification Number information from the PCM. If configuration information becomes lost or corrupted, the data can be obtained from DealerCONNECT
I found a TIPM from a wreck, (the TIPM took a hit, too), so I salvaged the useable parts, and didn't mind disassembling it to see how it is made.
I couldn't find a detailed wiring diagram for the TIPM, so this is more a visual than technical presentation.
This is a view of the TIPM as it sits in the engine bay.
Looking down on the TIPM with the cover open. There is a diagram and legend on the inside of the cover. The square gray items are mechanical relays. The item labeled "Ignition Off Draw" is the one you pull up to minimize the drain on the battery if the vehicle will not be run for an extended time. (Up to 30 days. Longer than that, disconnect the battery, and charge it periodically.)
The item labeled "Occupant Restraint Controller" should not be relied upon to make safe the ballistic components of the system. All instructions say to disconnect the battery negative terminal and wait several minutes to make it safe.
Here is a view of a relay with the cover removed.
A view underneath the TIPM.
The bottom cover has been removed, exposing the TIPM circuit board. Also, the layers of connector prongs have been separated. The view is looking up from the bottom.
This view is from the top looking down. The fuses and relays have been removed, since with the separated layers, there are no connector prongs in the sockets to retain them. Notice how the prongs on each layer are connected, and that all the prongs stick through each of the layers above and below (previous photo, too).
All the layers, back together.
A good view of the "brain" of the TIPM. In addition to the IC's and such, there are mechanical relays in the 7 white components on the board. It is this portion of the TIPM that is not serviceable by the dealer or consumer.
Here are two views of the relays on the circuit board. The bigger ones are double relays, the smaller are single.
Here is my best effort to identify the relays on the circuit board.
The check mark by the name indicates I was able to verify what it controls by tracing the circuit, exclusively between relay and destination, with a continuity tester. On the rest of them there were too many common points among them to isolate each relay.
When each of the systems was energized, I could hear the click of a relay with the aid of a mechanic's stethoscope, (not one of the big relays in the fuse box section of the TIPM).
There was no click sound when the headlights and fog lights were turned on, indicating those are controlled with a solid state relay.
ronjenx is online now
post #2 of 127 Old 04-23-2011, 03:39 PM
51M38
2011 JK Wrangler
Interesting, thanks for taking the time to post this.
51M38 is offline
post #3 of 127 Old 04-23-2011, 03:48 PM
JIMBOX
Super interesting ronjenx-thanx--question-
Did you find the "Elex ThrotleControl (ETC) Module, in that group ??
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 127 Old 04-23-2011, 04:05 PM Thread Starter
ronjenx
ronjenx's Avatar
JIMBO
The ETC, mounted to the intake, gets its instructions from the Powertrain Control Module, mounted on the driver's side (left) inner fender.
post #5 of 127 Old 04-23-2011, 04:15 PM
JIMBOX
Thank you everso-ronjenx
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #6 of 127 Old 04-24-2011, 05:17 AM
krutj
2009 JK Wrangler
Very nice write up...your studies are always interesting and informative, thanks.
-- Joel --
krutj is offline
post #7 of 127 Old 04-24-2011, 11:26 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Thanks' ronjenx
Are the relays of a standard type or are the proprietary to Chrysler?
Do you know the amperage rating of them?
As always, this will be archived in the F.A.Q.
Jim
JLC08JK is offline
post #8 of 127 Old 04-24-2011, 11:42 AM Thread Starter
ronjenx
ronjenx's Avatar
Originally Posted by JLC08JK View Post
Thanks' ronjenx
The relays are nothing special. They are labeled with the Chrysler number, most likely at the point of manufacture.
They are inexpensive, even from the dealer. (2-3 dollars on line, and 3-5 dollars at the dealer.)
I think they are rated in the 30 amp range, but can't verify that to the specific part number.
post #9 of 127 Old 04-24-2011, 11:51 AM
nwbronco
2014 JK Wrangler
Very nice. Wouldn't the biggest issue be the chipset(s)? That is where the logic programming is running for all the 'talking' the TIPM does the PCM and CCN isn't it? I know they flashed my TIPM and my interval wipers quit working. I know it's logic, I've swapped motors and the issue is with the Jeep. Service dept was interested when I mentioned it, shoulder shrugging was the only response though.
You bring up a good solution, too. If I round up a yard unit and find out what the dealer will charge to program it...
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
Kid's '08 Yellow JKU
'13 Black 10A Rubicon JKU
nwbronco is offline
post #10 of 127 Old 04-24-2011, 11:55 AM Thread Starter
ronjenx
ronjenx's Avatar
Bob K.
Removing and installing the same or new TIPM will not require dealer programming if the CCN and PCM are installed and operating properly.
I don't know if this applies to a used TIPM from another vehicle.
TIPM Installation:
1. Position the TIPM into the engine compartment.
2. Connect each of the seven TIPM wire harness connectors.
3. Position the TIPM onto the mounting bracket and push down until the mounting clips are fully seated.
4. Position the TIPM positive cable onto the mounting stud and install the retaining nut. Tighten the nut to 80 - 100 in. lbs.
5. Open the TIPM cover and fully seat the Airbag fuse holder (two fuses in one yellow carrier) and the Ignition Off Draw (IOD) fuse.
6. Connect the battery negative cable.
7. Close the hood.
8. Insert the ignition key and turn it to the “RUN” position and wait twelve seconds. The TIPM will collect the necessary vehicle configuration and VIN data from the CCN and PCM at this time. After twelve seconds turn the ignition key to the “OFF” position and then back to the “ON” position and verify proper vehicle systems operation.
If the information was lost or corrupted, it can be retrieved with the StarScan tool through DealerConnect.
post #11 of 127 Old 04-28-2011, 08:39 AM Thread Starter
ronjenx
ronjenx's Avatar
Here is a picture showing where 12v, (always hot), is available on a 2008 TIPM. If the same spots are open on yours, and you need some power, give them a try.
Also, I updated the view of the "brain", in the original post, above. It shows both halves, now.
Here is a pic showing where power is available when the key is in the RUN position.
If you wanted to tap the fuse slot from under the TIPM, and be able to use a fuse in the slot, I have identified the correct pin in the connector.
For example, to use the top slot (M9) identified in the picture, you would install an appropriate wire in connector C6, pin 28, under the TIPM. See this link to see a similar tap: http://www.jeepforum.com/forum/f96/s...ource-1248471/
post #12 of 127 Old 07-05-2011, 12:17 AM
gil1911jk
TIPM Installation:
7. Close the hood.
did you do this before it looks like you know what your talking about.so you are saying if i put it in i don't have to take it to dealer and pay all what money.i hope that is what your are saying
it's a 2008 jeep wrangler sahara.
gil1911jk is offline
post #13 of 127 Old 07-05-2011, 05:34 AM
WXman
This is interesting. On the Dodge Ram, this TIPM also controls trailer lighting. So if you have a weird trailer light issue, it may be rooted in the circuitry of this unit. On my Ram, I found a replacement TIPM in a junkyard and swapped it right in. Required no programming at all....you just had to make sure you found one from the same model year.
It's scary though how much stuff this box controls. I miss the days when you could just swap a fuse and get your trailer lights working again. With Chrysler stuff these days, that's not always the case.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #14 of 127 Old 07-05-2011, 07:16 AM Thread Starter
ronjenx
ronjenx's Avatar
I have not had to do this yet.
What I posted is from the 2008 factory service manual.
post #15 of 127 Old 07-05-2011, 12:46 PM
tavic
2010 JK Wrangler
Since the supply power locations you have pointed out are designed to receive fuses for options our rigs are not equipped with... Is there access below the TIPM to connect an aftermarket accessory to these empy slots and install fuse for a cleaner install? Or are we just better off just plugging in a spade connector and using an inline fuse type harness?
tavic is offline
Possessed Jeep.....TIPM issue?? Lights, horn wipers, etc.... Busa196 JK Wrangler Technical Forum 40 12-31-2015 06:01 AM
OEM PCV Valve Study ronjenx JK Wrangler Technical Forum 34 09-29-2014 08:25 PM
Has Anyone Ever Replaced Their Totally Integrated Power Module (TIPM)? fun JK Wrangler Technical Forum 11 09-19-2013 08:43 AM
TIPM Recall and Wipers? tebone77 JK Wrangler Technical Forum 11 07-10-2013 05:28 AM
Update on TIPM issue tebone77 JK Wrangler Technical Forum 5 01-05-2012 07:52 AM
