OEM stereo wiring diagram? - JeepForum.com
post #1 of 21 Old 03-14-2007, 07:07 PM Thread Starter
ksjeep226
OK , I give...
I have seen a wiring diagram of the stock stereo in here, but I can't find it!!!
To whomever posted it... will you give me the thread or copy the detail to this one?
Thanks.
2007 Wrangler
2005 Liberty
2002 VFR
ksjeep226 is offline
post #2 of 21 Old 03-14-2007, 10:46 PM
jdrogers
You mean like this?
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
post #3 of 21 Old 03-15-2007, 07:51 AM
lazerpunk
Who has the same thing for the MyGig radio????
'07 Sahara Unlimited, Red Rock Crystal, Auto, Dual Top, MyGig, 18" Wheels, Trailer Tow, Side Airbags.
2012 Unlimited Rubicon, Crush, Auto, Dual Top, 430N w/nav, Max Tow
lazerpunk is offline
post #4 of 21 Old 03-15-2007, 08:49 AM
jdrogers
Ummm... I do. What connections are you interested in?
Scottsdale, AZ
jdrogers is offline
post #5 of 21 Old 03-15-2007, 11:17 AM
lazerpunk
Specifically I am interested in making it play DVD's while in motion. So I will need to replicate the signal the radio receives to indicate it is in park. So probably the pinout for the plugs and where they go.
The MyGig for the non Wranglers indicate aux. screens and controls for the rear seat passangers and the ability to connect video games and play them on that screen. I was wondering what would take to add this to the wrangler.
Thanks
post #6 of 21 Old 03-15-2007, 01:54 PM
jdrogers
I'll check tonight but I can almost guarantee that there is no such signal on an individual wire.
The radios in the JK communicate with the rest of the vehicle using the CANbus system. Basically a local area network. So something like the PCM will send a message to the radio about being in park or drive and the radio will work accordingly.
Here are the pinouts and pictures of the radio (from the Dodge Nitro which is the same radios as the JK):
Radio Pictures and Pinouts
Scottsdale, AZ
jdrogers is offline
post #7 of 21 Old 03-15-2007, 10:59 PM
SpinningBull
So if this is true, then there would need to be a switch attached to the parking break wired into the bus that triggers a message. This is what we would need to spoof.
Anyone played with canBUS enough to know how to decode messages? The message format is like this:
I'd bet the 11bit (or 29bit) id field is unique to the brake, and the data-field contains "on/off" (i.e. probably a small field).
Any EE geeks out there have toys to read the messages in flight? It's been a few decades since I've had to read NRZ messages off a sniffer
2/13/07 - Ordered
2/19/07 - BG
4/28/07 - Gave up, found one on a lot!
RedRock, Sahara Unlimited, 6-speed, 4dr, 4x4, MyGig, Dual Tops, Tow Group, 18" wheels, Airbags, LSD - In My Driveway!
SpinningBull is offline
post #8 of 21 Old 03-16-2007, 05:27 AM
lazerpunk
While that might be true on manual trans wranglers, I have an automatic. I would need to replicate the neutral safety switch circuit. The E-brake on my JK does nothing with the DVD feature.
There has to be a workaround for this.
post #9 of 21 Old 03-21-2007, 11:00 AM Thread Starter
ksjeep226
You mean like this?
OK ... that was easy...
one question.... what is the twisted pair of white wires?
the harness has...
Red +
Black -
2 pair Gray = speakers
2 pair Green = speakers
AND
1 pair WHITE ?????????
2007 Wrangler
2005 Liberty
2002 VFR
post #10 of 21 Old 03-21-2007, 01:30 PM
jdrogers
That picture is actually the radio to amplifier wiring. Are you asking about the radio connector "C2"? Here are the radio connectors:
Scottsdale, AZ
jdrogers is offline
post #11 of 21 Old 03-21-2007, 03:05 PM Thread Starter
ksjeep226
That would explain why the colors didn't match.
Is #7 "amplified antenna feed" a 12v switched output?
Maybe it can be used for amplifier turn on.???
2007 Wrangler
2005 Liberty
2002 VFR
post #12 of 21 Old 10-17-2010, 05:58 PM
Unknown303
Has anyone tested to see if disconnecting the CAN bus pin does anything?
Unknown303 is offline
post #13 of 21 Old 10-17-2010, 06:32 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Thanks guys for all of the great information
This thread will now have a link in the F.A.Q.
Jim
JLC08JK is offline
post #14 of 21 Old 10-17-2010, 06:35 PM
Unknown303
I felt obligated to resurrect it as I'm messing around with stereos right now.
post #15 of 21 Old 10-17-2010, 06:39 PM
JLC08JK
JLC08JK's Avatar
I just noticed that it's over 3 years old
It will be of more use with the link
Future mod?
Jim
JLC08JK is offline
7 Speaker Stereo Pinout or Wiring Diagram? Sarge_ Audio, CB & Ham Radios, GPS, & Electrical 18 01-15-2014 01:05 PM
Need a 91 YJ wiring diagram....HELP PLEASE! danheit YJ Wrangler Technical Forum 6 01-11-2009 09:29 AM
Stereo Wiring Diagram Ghostdog2007 JK Wrangler Technical Forum 4 10-09-2007 06:24 PM
Factory stereo wiring diagram armysniper YJ Wrangler Technical Forum 3 06-04-2004 05:34 AM
Need stereo wiring diagram for my 97 xxxxxxxxxxxxxxxxxxxgksspot TJ Wrangler Technical Forum 7 03-17-2004 09:28 PM
