OEM Seat Fabric Replacement - JeepForum.com
post #1 of 8 Old 01-08-2012, 12:08 PM Thread Starter
tj98
I got roofing cement on the 2010 JK drivers seat bottom. I had been repairing a spot on the roof and had gotten some on my pants. Without thinking I jumped into the Jeep to move it. When I got out I left two skid marks of asphalt roofing tar on the gray seat bottom (gray seats with black inserts).
I used some Quick - N - Brite to get most of the stain out, but in the process I scrubbed a little to hard and damaged the fabric. It looks ok, but I will remember it everytime I get in the Jeep.
I'm not interested in seat covers or upgrading to leather, I just want my stock seat back like it was. Can anyone help me with a part number for the oem fabric for the drivers side seat bottom? 2010 JK Unlimited gray seats with black inserts.
Thanks.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline
post #2 of 8 Old 01-08-2012, 12:51 PM
smittycm
I did some searching with no luck, but here are a couple ideas...
1. Check with a local junkyard to look for wrecked 2010 that you could pull a seat from.
2. Call a dealer or auto shop that does insurance repair. They should be able to give you a part number for the seat at least. Not so sure they'd have the fabric alone.
3. Call an upholstery shop to see if they can get you stock fabric piece you're looking for.
4. Call a local dealer and find out who does the Katskinz leather upgrade for them. Maybe you'll luck out and find a place that did an upgrade and has the fabric they pulled off. I'm pretty sure they don't install the Katskinz leather over the top of the stock fabric. I've read of plenty of folks who have done the Katskinz leather upgrade on their 07-10 JK.
Good luck!
2012 JKU Sport S, RK 2.5" Max Travel, Bilstein Shocks, AEV Savegre Wheels, GY Duratrac 315/70R17
smittycm is offline
post #3 of 8 Old 01-08-2012, 12:51 PM
1222
RIP John
1222's Avatar
That’s too bad, I would want to do the same if it happened to me too. Probably be best to just go to a Jeep dealer parts guy to get whatever you need or maybe perhaps an auto upholstery shop has a catalog with the proper fabric.
Tell the truth now, are you sure it was roofing cement that made those “skid marks”?
1222 is offline
post #4 of 8 Old 01-08-2012, 02:01 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
upholstery shop mentioned above is a good route - your local dealer can refer you to the upholstery shop they use specifically for OE warranty repair
Mol is offline
post #5 of 8 Old 01-09-2012, 12:42 PM Thread Starter
tj98
That's probably the route I'll go, the JK was bought at a dealer a few miles away from me. Have a good upholstery shop nearby, one my family has worked with since the 60's so I know the work is good.
I need to get the trim code to be for sure but I think I found the cover on the mopar accessories site. Not cheap, should have paid someone to fix the roof
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
tj98 is offline
post #6 of 8 Old 01-09-2012, 12:48 PM
Mol
Mol's Avatar
You can always bedline the roof if it irks you enough, or buddy up with a body shop. Spraying the roof should be inexpensive enough. You don't need a high-quality, several stage paint and certainly no clear coat.
Good luck
Mol is offline
post #7 of 8 Old 01-09-2012, 01:54 PM
ricku
Upholstery shop is the way to go. They can get the exact OEM piece and install like new. I had a similar thing happen to me. Try and see if your homeowners insurance might cover it.
ricku is offline
post #8 of 8 Old 01-10-2012, 12:47 PM Thread Starter
tj98
That's an interesting thought, we've had several storms recently and I've had wind damage claims the last three years including twice for the same section of roof. The last time they raised my deductible instead of my rate, I don't want to chance it for this.
I found the cover online for under $200, taking Jeep to shop for quote at putting it on later this week. Should only be an hour or two labor. All of that is less than my deductible.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
tj98 is offline
Replacement stock seat fabric? hedrinbc JK Wrangler Technical Forum 0 07-04-2011 09:47 AM
Fabric Into Seat Covers???? MarineMachine YJ Wrangler Technical Forum 1 05-05-2011 01:32 PM
Seat back fabric burnt! itasor JK Wrangler Technical Forum 3 05-27-2009 08:11 AM
Question about removing seat fabric raskull TJ Wrangler Technical Forum 2 06-27-2007 09:14 PM
Fabric Seat Question TellyDSP YJ Wrangler Technical Forum 1 05-14-2003 10:35 AM
