OEM Rubicon Locker Study - JeepForum.com
post #1 of 35 Old 02-09-2013, 09:22 PM Thread Starter
ronjenx
ronjenx's Avatar
A forum member recently sent me his old Rubicon e-locker.
Here is a quote from the owner:
"...when wheeling in tough areas (sand, mud, rocks &tc.) I put the locker in for a while & then take it out, put the locker in for a while & then take it out, repeat. So, I've used it a lot. My Jeep has 105K miles & I'll bet 15-18K of that is off road."
It has seen some good use. The differential and dog clutch show very little wear.
The ring in the 3rd picture below looks quite worn, leaving a small lip at the inner diameter
That could be the cause of locker ratcheting.
Installing a shim to make up the difference has at least temporarily fixed it in some cases.
Here is a look at how the Rubicon e-locker works.
See this great video to review how a regular differential works:
ronjenx is offline
post #2 of 35 Old 02-09-2013, 10:29 PM
durable1
Great pictures. Very interesting post.
durable1 is offline
post #3 of 35 Old 02-10-2013, 05:36 AM
TheBoss
Well done Sir. You are a valuable asset to this forum.
TheBoss is offline
post #4 of 35 Old 02-11-2013, 10:05 AM
DBA2GO
Wahoo! That answers several of my locker questions. Now, this is a technical thread.
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline
post #5 of 35 Old 02-11-2013, 02:54 PM
MoreMud
One of the best explanations of a locking differential I've seen, thanks for putting it together.
2012 JKU Rubicon
Rugged Ridge Front bumper w/storage ends Rugged Ridge 8500 Winch w/ synthetic rope
PIAA ATP off road lights, full light bar, Terraflex leveling kit, Mygig lockpick
just getting started.....
MoreMud is offline
post #6 of 35 Old 03-17-2015, 04:09 AM
S_Bartfast
Firstly I want to congratulate you on a most excellent post. I've search long and hard for details on the Rubicon Locker and I must say you've done an exceptional write up here.
One question though....
Are you able to explain how it is the spider gears themselves rotate?
The reason I ask is that my front diff started making a horrible noise whenever I turn sharply while 4WD is engaged. I took it to the workshop and they pulled everything apart and found a nice shiney little bonus bit in my locker:
The first thing I thought was that it looked like the needle bearing in a uni cap and I started to wonder where the bearings that the spider gears roll on are. Would it be possible that this part is from one of the spider bearings?
In any event my diff has clearly experienced some serious violence and is in need of a complete rebuild. This is what one of the pins that go through the end of the spider shafts looks like:
S_Bartfast is offline
post #7 of 35 Old 03-17-2015, 07:34 AM
MrSundays
This is amazing. Thank you. A buddy of mine and I had a debate if it was an e-locker or a low compression clutch. Thanks for the clarification and explanation.
Sent from my pocket brick
SOLD- '13 JKR with lots of goodies
Current- '98 TJ Sahara: build coming in October
MrSundays is offline
post #8 of 35 Old 03-17-2015, 07:50 AM
Moezer
2015 JK Wrangler
So what would break this locker while off roading? and what will break when it does break the edged dog teeth or the pins
The way its set up its kinda like the spartan locker design
Moezer is offline
post #9 of 35 Old 03-17-2015, 08:08 AM
JIMBOX
Book of knowledge-
See this great video to review how a regular differential works: http://www.youtube.com/watch?v=K4JhruinbWc
If I didn't thank you before RJ, thanks again
More great info-thnks SB-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #10 of 35 Old 03-17-2015, 08:14 AM
Imped
Imped's Avatar
This is a cool thread....the operation is very well-explained for those that require good visuals. I recently built a pair of JKR44's with ARB's and have the factory lockers set aside collecting dust. They were in a fire so not everything is in perfect condition but they'd likely make for great spare parts doners. If any of you guys have interest in them feel free to PM me.
If this is against the rules, go ahead and delete it. But considering the extreme niche market of these parts I'd appreciate the exposure since I have no use for them but others most certainly do.
OlllllllO
IndyORV
Imped is offline
post #11 of 35 Old 03-17-2015, 08:50 AM Thread Starter
ronjenx
ronjenx's Avatar
S_Bartfast ,
The spider gears have no "bearings". They rotate on the shafts that go through them, and are pushed out on cupped and polished, hardened washers. There is enough oil on everything to handle the wear.
When you get the noise while turning sharply in 4wd, is it with the locker engaged?
What kind of noise is it, and what is the steering wheel doing during this.
Also, how much traction do you have at the time?
Did the pin you found cause damage to other parts?
I can't think of anything in the diff that would have small needle bearings. I'll take a close look at mine and see if there is a small pin that could fall out.
Do a search for the word Study in the title to find more threads like this one.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #12 of 35 Old 03-18-2015, 03:45 AM
S_Bartfast
Just in regular 4WD, nothing locked.
Aside from the noise everything else is fine. Steers fine, traction's fine. It actually worked perfectly, just sounded awful!
Here's a short video demonstrating the sound before it was disassembled:
I'm in Australia and we drive on the "Queen's Side" here
(And yes, I know you should never engage 4WD on bitumen)
It was actually my mechanic who found it (I'm no mechanic myself, just an interested geek) and the second picture is the only part he showed me specifically. I believe the second pic is a "cross pin retainer". I saw the other parts and they kind of looked fine to me but I wouldn't really know. My mechanic didn't mention anything about them specifically but said the "bonus" bit must have gone through the gears at some stage and caused the damage to the second part. If you look closely you can see the pin is both scuffed and bent, and it you look really closely you can actually see that the "bonus" bit is also slightly bent.
Here are links to the full resolution images:
Pin (2.7MB)
BonusBit (2.8MB)
(let me know if you can't download the full res images)
No, nor could my mechanic
Will do.
I think I came across your "Totally Integrated Power Module" thread before. That was a really good piece of work to.
post #13 of 35 Old 01-02-2016, 05:13 PM Thread Starter
ronjenx
ronjenx's Avatar
For those of you who have worn/broken OEM Rubicon axle locker actuators, new actuators are now available.
I have seen them at the dealer for $62, and from on-line MOPAR parts dealers for less.
Edit to add (4 March 2016):
The price of the actuator now, just 2 months after it was only $62 at the dealer, is about 5.5 times higher.
Here is a picture of the part of the actuator which wears to the point of diminished locking ability. The worn ring is identified in the picture.
Another thing that breaks is the harness, as shown in the picture.
Here is a picture of the new actuator with a not-worn ring.
Here is a picture of the new actuator, and the parts that come with it.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #14 of 35 Old 01-02-2016, 08:33 PM
222Doc
222Doc's Avatar
nice find
222Doc is offline
post #15 of 35 Old 01-04-2016, 02:32 PM
DBA2GO
Very good to know. 3 years too late for me; but, great for everyone else. Maybe I'll need another actuator in another 100k miles.
DBA2GO is offline
