OEM PCV Valve Study - Page 2 - JeepForum.com
post #16 of 35 Old 08-04-2010, 03:08 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Other than the possible affects to performance created by the increase in pressure, The next weak link would be the valve cover gaskets.
What other possible affects could there be?
Jim
JLC08JK is offline
post #17 of 35 Old 08-04-2010, 03:17 PM Thread Starter
ronjenx
ronjenx's Avatar
That's the thing. Without knowing the flow rate of the valve, there is no way to know if the result is more, or less, crankcase pressure, or if the intake sees it as a bigger, or smaller, intake leak.
ronjenx is online now
post #18 of 35 Old 08-04-2010, 03:46 PM
peenkfloeed
Originally Posted by ronjenx View Post
Thanks for the reminder. I grew up watching his show on Saturday mornings back in the '50s and '60's. He was on TV for quite a few decades.
Don Herbert (Mr. Wizard) passed away in 2007 at the age of 89.
I grew up watching him in the 80's. I would probably still be transfixed by all the amazing experiments again if they would play some re runs.
peenkfloeed is offline
post #19 of 35 Old 10-22-2010, 02:13 PM
zach847
Install of PCV Valve
I just want to say Thank You for the pics n detailed info for the install of the PCV I followed them and had no problems installing it.
zach847 is offline
post #20 of 35 Old 11-13-2010, 08:22 AM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Thank you for the pics and the write up. Good work!
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #21 of 35 Old 11-20-2010, 08:44 PM
JeffinWesternWA
2010 JK Wrangler
Did you find your PCV was dirty/clogged defectoive when removing? I often liked to (previously) remove and lightly clean 'em along w/ the breather hoses every other oil change or so in past, maybe I can forego this for a while now?
Though I'll still probably opt to change it (PCV), and the plugs (cuz they seem to "Weld" to the heads if left in longer), air filter (2nd time), brake fluid (at least empty/refill the resoivoir every other oil change to keep clean fluid through the system), clean the TB butterfly area (every other OC) and maybe the Wal-Mart $18 fuel system cleaning at 60K~ before the plugs also...and all the fluids based on the manual severe service interval. Especially since I only put 6K~ miles a year on my vehicles..
JeffinWesternWA
JeffinWesternWA is offline
post #22 of 35 Old 11-21-2010, 07:24 AM
Thunderstrike
2009 JK Wrangler
Originally Posted by JeffinWesternWA View Post
Though I'll still probably opt to change it (PCV), and the plugs (cuz they seem to "Weld" to the heads if left in longer), air filter (2nd time), brake fluid (at least empty/refill the resoivoir every other oil change to keep clean fluid through the system).
Good idea about break fluid change... what is the resoivoir capacity?
I want to buy right size fluid.
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
post #23 of 35 Old 11-21-2010, 12:29 PM
JeffinWesternWA
2010 JK Wrangler
I buy 2-3 of the mini bottles and toss any opened ones left , they (plastic bottles of brake fluid) are hydroscopic so not good to keep around, ... even using a turkey baster and suction/refill every 18K miles will help keep the system clean w/ fresh fluid. Good maintenance also for vehicles w/ refillable hydraulic clutch resoviors (JK's are sealed though). Do the same w/ your Power steering fluid too. Follow the manual for proper fluid spec...
JeffinWesternWA
post #24 of 35 Old 11-21-2010, 01:25 PM
JLC08JK
JLC08JK's Avatar
I buy 2-3 of the mini bottles and toss any opened ones left , they (plastic bottles of brake fluid) are hydroscopic so not good to keep around, ... even using a turkey baster and suction/refill every 18K miles will help keep the system clean w/ fresh fluid. Good maintenance also for vehicles w/ refillable hydraulic clutch reservoirs (JK's are sealed though). Do the same w/ your Power steering fluid too. Follow the manual for proper fluid spec...
Just an FYI, It's my understanding that the clutch cylinder on the JK actually gets its fluid from the brake reservoir. So you are essentially servicing it without even knowing it.
Jim
JLC08JK is offline
post #25 of 35 Old 11-21-2010, 02:58 PM
Thunderstrike
2009 JK Wrangler
What do you use to take out old fluid?
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
post #26 of 35 Old 11-22-2010, 01:00 PM
JeffinWesternWA
2010 JK Wrangler
The thanksgiving turkey baster, what else??
JeffinWesternWA
post #27 of 35 Old 11-22-2010, 06:01 PM
Stugen
Oh man, I can just picture that
Stugen is offline
post #28 of 35 Old 11-22-2010, 06:04 PM
JeffinWesternWA
2010 JK Wrangler
gravy anyone??
JeffinWesternWA
post #29 of 35 Old 11-22-2010, 06:16 PM Thread Starter
ronjenx
ronjenx's Avatar
And you don't need to spend the money on the Deluxe Automatic "Master-Baster".
The regular hand operated baster will do just fine.
post #30 of 35 Old 04-30-2011, 05:21 PM
Charles
2017 WK
Made a video.
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
JK Wrangler , pcv , pcv valve , wrangler
OEM Parking Brake Lever Study ronjenx JK Wrangler Technical Forum 21 08-18-2013 11:39 AM
penetrating oil study 03rubiconMG TJ Wrangler Technical Forum 95 06-16-2010 08:29 PM
OEM Ball Joint Study ronjenx JK Wrangler Technical Forum 25 06-05-2010 11:12 PM
Engine Oil Filter Study HotDogWater YJ Wrangler Technical Forum 1 10-09-2006 08:15 PM
Oil filter study pyro9862 YJ Wrangler Technical Forum 5 07-18-2005 12:39 PM
