OEM Parking Brake Lever Study - Page 2 - JeepForum.com
post #16 of 22 Old 03-10-2011, 05:23 AM
CharlieHarper
A big thanks
thanks for the info! I now know what i need to replace and I bet it is not cheep!
CharlieHarper is offline
post #17 of 22 Old 03-27-2011, 12:32 AM
phant0omx
2012 WK
Coming over from the WJ board. Has anyone had the cable snap at the handle end releasing the tension in spring? The WJ brake handle is slightly different in that it doesn't have the extended drum on the other side of the cable drum. It has the riveted section then the cable drum sprocket that holds the tension of the spring. There is a stopper arm that when the handle is pulled up, is engaged to the sprocket and pulls it tight to engage the parking brake.
I have attached the parking brake cable from the handle to the equalizer bar, but it appears the the cable drum sprocket is wound to far to be able to engage with the arm to pull it up. I have checked the replacement part and it is the same length of the OEM.
I am at a stand still now and need any kind of help and at wits end.
Thought this was a long shot, but would try anyway.
Thanks
phant0omx is offline
post #18 of 22 Old 03-27-2011, 01:08 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
It sounds like you need to give the drum one full turn before attaching the cable.
I have no experience with yours so this is just a guess!
Jim
JLC08JK is offline
post #19 of 22 Old 06-02-2013, 09:41 AM
gumbellion
Thread revival.
I have been searching on this as I just had the SNAP on my 2007.
Anyone done a write up on how to replace that spring, or have some tip/tricks on its replacement?
I really dont want to pay someone to fix this, so would like to get the parts ordered and fix it my self. I normally never use the e-break but its a real pain in the *** when putting the boat in the lake without it
Thanks
gumbellion is offline
post #20 of 22 Old 06-02-2013, 09:43 AM
gumbellion
post #21 of 22 Old 08-18-2013, 09:51 AM
JonesN
Thanks for this!! I was removing my console yesterday...it was catching on the brake; so I had the hubby come out to help pull it up a little more....thats when it snapped!! The pictures really helped in understanding!! Thank you!
JonesN
I tried to melt my JK down and inject it, but it didn't work!! I tried to chop it into a fine powder and snort it, but it didn't work!! So I will continue to check the forum 100X a day, and get butterflies everytime I get a new toy for it.
JonesN is offline
post #22 of 22 Old 08-18-2013, 11:39 AM
SubAtomicGenius
2011 JK Wrangler
^^^ My "hubby" came out to help! You go, girl!
SubAtomicGenius is offline
JK Wrangler , parking brake , problem , troubleshoot , wrangler
Strange Brake Problems & Parking Brake issue Tmsnake1 TJ Wrangler Technical Forum 16 02-24-2012 07:19 AM
parking break problem, i need my parking brake ClassicRiderhp TJ Wrangler Technical Forum 2 04-21-2010 09:21 AM
parking break lever coming undone GRN_BEAST95 YJ Wrangler Technical Forum 12 07-12-2009 12:45 AM
97 TJ Emerg/Parking brake lever removal help rnestved TJ Wrangler Technical Forum 4 11-24-2008 07:38 AM
Has anybody replaced the foot parking brake with hand brake jake100 YJ Wrangler Technical Forum 0 06-11-2002 10:19 PM
