OEM Mechanical Fan Retrofit - Page 4 - JeepForum.com
post #46 of 53 Old 07-14-2013, 05:33 PM Thread Starter
ronjenx
ronjenx's Avatar
Originally Posted by Vin View Post
I was actually thinking of this thread since we're having such a hot summer in the northeast. I'm glad to see everything running well.
It's a modification I feel good about every time I drive the Jeep; on the road, or in the woods.
ronjenx is offline
post #47 of 53 Old 07-21-2013, 07:54 PM Thread Starter
ronjenx
ronjenx's Avatar
Update:
I decided to install the electric fan that is designed to be used with the mechanical fan. It has been in the 90's here lately, so I figured it's a good time to try it out.
I haven't seen much difference in engine/transmission, etc, cooling. The engine is still running around thermostat temp, and the transmission continues to run in the 90F - 130F range.
I have seen a pretty good improvement in A/C performance, though.
With just the mechanical fan, the output temp of the air from the center vents has been in the warmer half of the 20 range of acceptable performance.
For example, the acceptable output temp at 90F ambient is 48F to 69F, when all the controls are set for MAX cooling.
With just the mechanical fan, the output temp has typically been around 60F. Not great, but within the acceptable range.
After adding the electric fan, which comes on when A/C is selected, the output temp (@ 90F ambient) is in the cooler half of the range, around 52F.
So, when it was in the mid 90’s, with the high sun beating down on my black Jeep, there was a very noticeable improvement in the A/C’s ability to keep it cool inside the Jeep.
ronjenx is offline
post #48 of 53 Old 07-21-2013, 09:32 PM
VEGASROBBI
The electric fan will have a great deal of effect on AC performance. The stock electric fan will come on low at about 240 psi and high around 305 psi.
It's scary how high condenser pressures get without proper airflow. It will shoot to over 400 psi when the PCM shuts off the compresser based on info from the pressure transducer. If it continues to climb a safety relief valve or fuse will blow, hopefully before a line or fitting.
Jeep recommends shutting the AC off on fan clutch equipped vehicles at low speed, when you need it most.
Your observations show the benefits of cooling air independent of engine speed. Seems like guys dwell on the engine and trans temps and ignore condenser pressure; when it's 120* out here and I go for a test drive I carefully watch condenser pressure, I've seen systems blow and it's not fun. AC systems protect themselves by shutting off the compressor at high pressures and outlet temps rise, older systems run at high pressures can leak or fail.
Unbeknownst to you your AC pressures were most likely approaching 400 psi, I'm glad you added the electric fan. I find Jeep shuts off the compressor at 41* and back on at 46* EVAP temp, this keeps the evaporator from freezing or creating excessive water formation on humid days, we shoot for 37* to lower outlet temp a bit. This is the reason the resistor mod works. The 11' up auto air are a whole new ball game.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #49 of 53 Old 07-21-2013, 09:44 PM
duneslider
That's interesting to note about the AC, that was something that I have never heard anyone explain. My assumption would be that this is really only an issue at slower speed right? My temps remain great when I am cruising at freeway speeds, though I have never monitored the ac line pressures. I only see issues with temps when I run at the slower speeds.
I will add the electric fan to my list. I was debating whether I needed it or not.
duneslider is offline
post #50 of 53 Old 07-21-2013, 11:09 PM Thread Starter
ronjenx
ronjenx's Avatar
Your previous comments about the A/C were in the back of my mind when I decided to try the addition of the electric fan. I didn't monitor the pressure in the system. I assume all was well because the outlet temps were within limits, and there was no indication the system was shutting down.
The electric fan will serve as a backup to the mechanical fan, in addition to it's benefit to the A/C system.
ronjenx is offline
post #51 of 53 Old 09-25-2015, 01:07 PM
SoK66
2009 JK Wrangler
What a great thread! Thanks to Ronjenx for all the research, wrench time and postings. Since new, even with a trans cooler I've felt my '09 JKUR just had silly underhood temps that could be ameliorated a bit with a mechanical fan setup. After reading Ron's report I was concerned re: A/C pressures. Looks like there's a plug & play setup that kills both birds. Thanks again!
Jeeps: Where my 401(k) went to die!
SoK66 is offline
post #52 of 53 Old 09-26-2016, 06:50 AM
Grecy
Grecy's Avatar
2011 JK Wrangler
Thanks for all the detailed information.
I'm driving around Africa right now in my 2011 JK (3.8) 6-speed, and I'm encountering some seriously hot temperatures that make me want a constantly running fan.
Has anyone done this mod to a 6-speed manual trans JK?
In the parts list it says the shroud is for automatics (I assume to accommodate the trans cooler). Is there a different part number for the standard transmission Jeeps?
Thanks very much,
-Dan
Around Africa in a Jeep Wrangler JK @
(previously Alaska->Argentina in a TJ)
Follow:
- Everything you need to know to Travel Overland across a country, continent or the world.
Grecy is offline
post #53 of 53 Old 09-26-2016, 03:46 PM Thread Starter
ronjenx
ronjenx's Avatar
Thanks very much,
-Dan
There is another part number for the shroud for manual transmission JKs.
I think it's 68039594AA. Don't know this for sure, so research the number if you want one.
Haven't researched the differences.
Looking at mine, it's not obvious what the difference would be.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
AC retrofit dlloydj TJ Wrangler Technical Forum 0 03-29-2010 09:17 AM
A/C Retrofit bdemeyer TJ Wrangler Technical Forum 0 08-14-2009 04:08 PM
retrofit greenmachine99 TJ Wrangler Technical Forum 6 08-06-2006 01:31 AM
Retrofit ABS? Mac204 TJ Wrangler Technical Forum 8 12-02-2004 06:09 PM
Retrofit ABS onto my TJ bluesmoke TJ Wrangler Technical Forum 15 10-22-2003 02:57 PM
