OEM Fog Light Switch Cable - JeepForum.com
post #1 of 10 Old 08-16-2010, 07:13 PM Thread Starter
Cibert
Could some one Know Where is the OEM FOG Light Cable on a WRANGLER X Unlimited SAHARA 2007 ?? I Need to Attach some new FOG Lamps to the Original Fog Light Switch But I Cannot Find The Cable inside the HOOD, Can somebody Share some images to know where to find it ? THANKS.
I'm now kind of frustrated
Thanks in advance for all your answers.
Cibert is offline
post #2 of 10 Old 08-16-2010, 08:11 PM
1222
RIP John
1222's Avatar
The cable runs along the back of the bumper kinda inside a bit side to side. Not sure where it plugs in at, never looked.
(2011-2016)
1222 is offline
post #3 of 10 Old 08-16-2010, 08:26 PM
ronjenx
ronjenx's Avatar
Tapping into the OEM fog light switch wires will not turn on your new lights.
Connecting lights to the switch wires may actually screw things up.
This is how the fog lights work:
"The Steering Control Module (SCM) monitors a hard wired multiplex input from the left multi-function switch to determine whether the fog lamps are selected, then sends an electronic front fog lamp switch status message to the EMIC over the Local Interface Network (LIN) data bus and the EMIC relays an electronic front fog lamp request message to the TIPM over the CAN data bus.
"When the TIPM receives a front fog lamp request message it then controls front fog lamp operation by controlling a battery voltage output through high side drivers on right and left fog lamp feed circuits. The TIPM also sends the appropriate electronic message back to the EMIC to illuminate or extinguish the front fog lamp indicator. In certain markets where required, the TIPM will automatically de-energize the front fog lamps any time the headlamp high beams are selected."
ronjenx is offline
post #4 of 10 Old 08-16-2010, 09:36 PM
fernjack
Hey ronjenx could you use the hot to the fogs as a trigger for a relay on aux lights without messing with the canbus ? Thanks ......
07' Rubi Unlimited 6spd. , Rescue green #64 CDN , 35x12.5 mudders
Rick .
fernjack is offline
post #5 of 10 Old 08-16-2010, 09:44 PM
ronjenx
ronjenx's Avatar
It depends on if there is straight power on the line. If it is a pulse width modulated voltage, like (I believe) the headlights, the relay may buzz.
The description of the fogs says the TIPM sends battery voltage to the fogs, so I suspect your suggestion will work.
ronjenx is offline
post #6 of 10 Old 08-16-2010, 09:54 PM
fernjack
Thanks , I thought it might due to the small amount of current needed to trip the relay .
Rick .
fernjack is offline
post #7 of 10 Old 08-17-2010, 12:18 AM Thread Starter
Cibert
It is a SAHARA 4x4 4 doors I'm GOing to Replace The new Ones, BUT The new Ones are H3 and It Appears Like The OEM Relay Its not compatible because the Bulb get to much Energy (not enough to damage it) but it turn on and 2 seconds later it turns off.
I'm going also to put a new pair and for both cases If I Connect The Fog Lights To The Battery It is goes well But They are not turned on with the Original Fog Light Switch.
I don't Know what To Do, What Do you Recommend Me ?? =D
Cibert is offline
post #8 of 10 Old 08-23-2011, 12:25 PM
Ghethro
OEM Fog Light Switch Cable followup?
Would be nice to get a follow-up on this post? I'm in the same boat right now, trying to wire up KC Apollo (55w) fog lights to work off the OEM foglight switch on the steering column. Any thoughts?
I may need to start a new thread...
Ghethro is offline
post #9 of 10 Old 08-23-2011, 12:45 PM
Vin
Just like Ron and Fern said, go through a relay instead of strait to the lights.
Vin is offline
post #10 of 10 Old 08-23-2011, 08:07 PM
JK-Ford
X2, Connect the 12 volt positive wire from the fog light circuit to an aftermarket relay. Then, when you use your OEM fog light switch, your new lights will turn on. This method will work just fine unless you are using your OEM fog lights as Daytime Running Lights ( DRL's ).
The Green Monster
2007 JK-XS 2-door Jeep Green
130w KC 6" Long Range on Smittybuilt brackets
130w KC 6" Driving Beams on Grab Bar Mod
Rock light mod
Reverse light mod
JK-Ford is offline
compatibility , fog light , JK Wrangler , questions , wiring , wrangler
2003 TJ - Moving fog light switch from MFS to toggle switch TJeep_1999 TJ Wrangler Technical Forum 10 08-05-2015 04:07 PM
Intermittent wiper switch CABLE needed Obi-Wan YJ Wrangler Technical Forum 10 08-16-2011 05:05 PM
Using stock fog light switch to trigger AM light relay vohk TJ Wrangler Technical Forum 3 01-17-2010 12:50 PM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
Replacing fog light stalk switch with dash mounted switch? Imped TJ Wrangler Technical Forum 7 08-31-2008 12:58 PM
