OEM E-Disco (Smartbar) Study - JeepForum.com
 2Likes
post #1 of 32 Old 12-01-2010, 09:56 PM Thread Starter
ronjenx
ronjenx's Avatar
I have been wondering how the Smartbar works, and if it can be successfully disassemble, serviced, and reassembled.
The Smartbar is made by American Axle & Manufacturing.
Mechanically it is pretty simple. It's the computer control and the circuit board that will most likely cause problems. I was hoping to see a way to make it manually operated.
Here is a picture of the electrical connector. I don't know if anyone has wired in a bypass switch (like the lockers), but it looks like the computer control is too involved.
ronjenx is online now
post #2 of 32 Old 12-02-2010, 12:32 AM
Imped
Imped's Avatar
Eh. I'd ditch that silly contraption that's not doing you any good when disconnected and get a Currie AR. Nice job on the analysis, though.
OlllllllO
IndyORV
Imped is offline
post #3 of 32 Old 12-02-2010, 02:40 AM
1222
RIP John
1222's Avatar
Wow, very impressive ronjenx. Do you just happen to have one lying around or does it belong on your Jeep?
I always wondered how it worked. Great write-up.
Imped, curious why you say its not doing you any good when disconnected. It makes a big difference on my Jeep. It has also been around for several years now with lots of satisfied people. Is it possibly that you have TJ (Iíve had a couple of TJís and like them allot) which of course doesnít have one? I donít need a lesson on how the Currie product works, Iím well aware of that. I also know itís a great product too.
Now just suppose for fun that you had a JK with the Smartbar, would you actually remove it and install a Currie one instead? I think I already know what your answer will be but still go ahead with it.
(2011-2016)
1222 is offline
post #4 of 32 Old 12-02-2010, 09:05 AM
Imped
Imped's Avatar
If you know how the Currie works (just a torsion bar), then you should understand why being totally disconnected in the front is putting you at a disadvantage. In that situation, your rear sway bar is the only member influencing the behavior of the frame relative to the axles, which causes natural instability. Having a similar member acting on the front of the frame in an equal but opposite manner cancels out that instability, keeping the frame/body neutral relative to the axles. Steep climbs, ruts and off-camber situations are also made much more comfortable due to the extra influence and control. I think it's obvious, but regardless of JK or TJ or 3, 4, or 5 links, link suspensions benefit from having a front and rear sway bar. If I were to purchase a JK Rubi, the FIRST thing I would do is remove and sell the e-sway bar system, purchase a Currie AR, and pocket the rest. Then would come the housing beef, gears, and 37's.
OlllllllO
IndyORV
Imped is offline
post #5 of 32 Old 12-02-2010, 09:12 AM
jstrubberg
2009 JK Wrangler
Have their been problems with the electronics on the disco's?
You know what they say about the interest rate on borrowed trouble.
jstrubberg is offline
post #6 of 32 Old 12-02-2010, 10:28 AM
thejdj
thejdj's Avatar
2016 WK
Great pics and nice info. Thanks for sharing.
2016 WK2 Overland 4x4 3.6 Granite Crystal 6K
thejdj is offline
post #7 of 32 Old 12-02-2010, 10:28 AM
krutj
2009 JK Wrangler
Great write up ronjenx.....
I'm also curious about your supply of parts to disassemble..
All of your studies have been very informative and detailed, thanks....
-- Joel --
krutj is offline
post #8 of 32 Old 12-02-2010, 10:37 AM
ncb
Great write up as always. Reminds me of airframe and powerplant tech classes.
0848YJ likes this.
ncb is offline
post #9 of 32 Old 12-02-2010, 10:47 AM
Washi
Rockbiter
Washi's Avatar
2009 JK Wrangler
Who did you get your A&P through?
0848YJ likes this.
Washi is offline
post #10 of 32 Old 12-02-2010, 01:20 PM
Vin
I was contemplating this, BUT would this effect the ESP? Now the computer think there is no sway bar connected. It sucks having 5 computers running your rig.
Vin is offline
post #11 of 32 Old 12-02-2010, 01:28 PM
1AAdam
great write up! i was suspect of it at first but i feel this system will work fine now! i am sure it can be made manually operated but the ESP may freak out. i don't know if they talk to each other though. i hope not!
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #12 of 32 Old 12-02-2010, 01:39 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Added to the F.A.Q.
Thanks again Ron
Jim
JLC08JK is offline
post #13 of 32 Old 12-02-2010, 04:14 PM
ncb
South Western in Michigan. Small school in the middle of nowhere. They were a diamond in the rough. They since shut down the AMT program from small class sizes.
ncb is offline
post #14 of 32 Old 12-02-2010, 04:19 PM
Imped
Imped's Avatar
No clue but if so, that SUCKS. Computers FTL.
OlllllllO
IndyORV
Imped is offline
post #15 of 32 Old 12-02-2010, 04:34 PM
JLC08JK
JLC08JK's Avatar
It looks like the default position is with the sway-bar fully connected.
Therefore the computer is told when the bar is disconnected and will not receive a signal otherwise.
Thats my guess!
Jim
JLC08JK is offline
OEM PCV Valve Study ronjenx JK Wrangler Technical Forum 34 09-29-2014 08:25 PM
penetrating oil study 03rubiconMG TJ Wrangler Technical Forum 95 06-16-2010 08:29 PM
Engine Oil Filter Study HotDogWater YJ Wrangler Technical Forum 1 10-09-2006 08:15 PM
Oil filter study pyro9862 YJ Wrangler Technical Forum 5 07-18-2005 12:39 PM
hp30 disco to non-disco conversion Bucket110 TJ Wrangler Technical Forum 2 06-22-2005 01:46 PM
