OEM Ball Joint Study - Page 2 - JeepForum.com
post #16 of 26 Old 02-03-2010, 09:27 PM
Ole Yeller
Ole Yeller's Avatar
2010 JK Wrangler
Sorry. I did contribute to it.
2007 Patriot Limited
2006 Unlimited Rubicon
2006 Commander
2000 TJ Sport
My previous Jeeps
1992 Wrangler S (Ole Yeller)
1985 Cherokee Pioneer
1989 Cherokee Laredo
1995 Cherokee Country
1996 Cherokee Country
1996 Grand Cherokee Laredo
Ole Yeller is offline
post #17 of 26 Old 02-04-2010, 03:44 PM
DeepSky
Simply amazing post ronjenx. Again, thanks for putting this together, it certainly helped me.
I have a question: how far out of spec can bad ball joints put your camber?
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #18 of 26 Old 02-04-2010, 04:20 PM Thread Starter
ronjenx
ronjenx's Avatar
I believe you would replace them for other symptoms (noise, vibration, shimmy, outright breaking off, etc), long before they would cause camber, castor, or toe in, to go out of spec.
But, to answer your question: I don't know.
ronjenx is online now
post #19 of 26 Old 02-04-2010, 04:56 PM
Hellbound13
My first set put the camber off by .3
Hellbound13 is offline
post #20 of 26 Old 02-04-2010, 05:16 PM Thread Starter
ronjenx
ronjenx's Avatar
Do you recall what the measured play was?
post #21 of 26 Old 02-04-2010, 05:21 PM
Hellbound13
No I just remember going for an alignment and the shop told me I needed new ball joints. I then did a pry bar test and they were shot.
post #22 of 26 Old 04-20-2010, 08:55 AM
ricrac
rebuildable ball joints !
Dynatrac makes rebuildable ball joints for the JK , downside is they cost big coin, about $580.00. But I guess if you're running a lift and big tire/ offset rims and are replacing oem joints every 10K miles or so the Dynatracs may be worth the money.
Are you ready to wheel this weekend?
ricrac is offline
post #23 of 26 Old 06-05-2010, 04:30 PM Thread Starter
ronjenx
ronjenx's Avatar
Here is a comparison between the OEM JK ball joints and Crown replacement ball joints:
(A review of the first post in this thread may be helpful.)
As you can see, the OEM JK lower ball joint has a larger ball, for more bearing surface.
The Crown's liner has a hole in the top, and grooves (grease groves?), just like the OEM joint.
The Crown upper ball joint is a slightly different design than the OEM joint.
It has a spring in the top that pushes on the white plastic spacer, which pushes on the pin.
The top cap on the crown is steel. I had to put it in a vise to hold it together because the spring has a high compression load.
The plastic liner and the housing bore have a 0.005" taper toward the bottom. Not nearly as much as the OEM joint has.
post #24 of 26 Old 06-05-2010, 05:58 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
So from this comparison the O.E.M. Ball joints appear to be preferred over the Crown replacements correct?
Or maybe the O.E.M. Lowers and the Crown Uppers!
P.S. Thank you for the great research
Jim
JLC08JK is offline
post #25 of 26 Old 06-05-2010, 08:19 PM Thread Starter
ronjenx
ronjenx's Avatar
My opinion is both brands are inadequate for the JK.
Now that there are some Dynatrac ProSteer ball joints on a few JK's it will be interesting to see how they hold up.
post #26 of 26 Old 06-06-2010, 12:12 AM
JLC08JK
JLC08JK's Avatar
Hopefully the AfterMarket will be able to supply our demand sooner rather than later!!!
I've seen better steering joints on a "RadioFlyer" maybe they could be adapted.
Jim
JLC08JK is offline
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 11:59 AM
U-Joint and Ball-Joint question gcally TJ Wrangler Technical Forum 5 02-18-2009 11:28 AM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 01:27 AM
Bad ball joint or not? hkiss96 TJ Wrangler Technical Forum 1 08-19-2005 08:00 AM
front wheel problems (u joint, ball joint etc) ohhpe YJ Wrangler Technical Forum 0 06-05-2005 04:40 PM
