OEM Ball Joint Study - JeepForum.com
post #1 of 26 Old 02-01-2010, 10:55 PM Thread Starter
ronjenx
ronjenx's Avatar
I recently received some old ball joints from Hellbound13. Thanks Hellbound!
I cleaned them up and dissected them to see how they are made, how they function, and determine if they can be made grease-able.
This is what I came up with:
The lower ball joint is designed to bend, rotate, and have no axial or radial movement. They come from the factory with no grease fitting. An inspection of the internal parts revealed it is designed to be grease-able. The amount of grease found in the ball joint was no more than what would be called "butter lubricated" during assembly.
The plastic socket liner has a hole in the top, and grease grooves going down the inside where the ball resides.. The very top of the ball is flat, making a nice grease reservoir. The top of the ball joint body can be drilled in the center without risk of damage, and tapped, providing suction is used to keep the filings from entering the joint during each operation.
There isn't room for a regular zerk fitting because the u-joint yokes will hit. At least that's the case on my Rubicon axle. A flush fitting would work. Here is one source: h**p://www.saeproducts.com/flush-grease-fitting-AK18F.html
Installing a grease fitting in this joint, on the vehicle, would be difficult. I would recommend doing it on the new joint, before installation.
The upper joint does not bend. It can rotate and is designed to allow for axial movement, and no radial movement.
Installing a grease fitting in the upper joint is not recommended, as the pressure would likely blow out the thin plastic cover on the top.
The plastic liner in the joint is designed to make up for radial wear, for a while, at least.
So, installing grease fittings in only the lower ball joints may sill extend the lives of all four ball joints.
ronjenx is online now
post #2 of 26 Old 02-02-2010, 01:16 PM
Ole Yeller
Ole Yeller's Avatar
2010 JK Wrangler
Wow!! Very impressive!!
2007 Patriot Limited
2006 Unlimited Rubicon
2006 Commander
2000 TJ Sport
My previous Jeeps
1992 Wrangler S (Ole Yeller)
1985 Cherokee Pioneer
1989 Cherokee Laredo
1995 Cherokee Country
1996 Cherokee Country
1996 Grand Cherokee Laredo
Ole Yeller is offline
post #3 of 26 Old 02-02-2010, 01:42 PM Thread Starter
ronjenx
ronjenx's Avatar
Thanks. It was a fun little project. I intend to put the grease fittings in my lowers to see if it makes them last longer.
I am also looking for an old JK front unit bearing for a similar project; mainly to see if my XJ hub tools will work on the JK hub.
post #4 of 26 Old 02-02-2010, 01:43 PM
N2rock
N2rock's Avatar
I'll second that- VERY IMPRESSIVE!
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #5 of 26 Old 02-02-2010, 04:00 PM
muttytruckster
This is the perfect detailed description a person needs to understand the ball joint. Awesome job, thanks for taking the time to post this.
2007 Jeep Wrangler Unlimited Rubicon -JKUR
Rescue Green 6-Spd, 33" KM2s- 17 x 8 BlackRock Series 909 wheels, Stainless Steel Gibson Exhaust & AFE Air Intake, Superchips, Aberle Front Bumper&10.5K Winch, PiAA ATP Lights
muttytruckster is offline
post #6 of 26 Old 02-02-2010, 05:20 PM
USAntigoon
Retired from Forum
ronjenx
Thanks for sharing..Job well done...
USAntigoon is offline
post #7 of 26 Old 02-02-2010, 06:20 PM
Hellbound13
Hmm, my lower ball joints seemed worn when I did the pry bar test, but now seeing it sawed in half it does not seem so..
Hellbound13 is offline
post #8 of 26 Old 02-02-2010, 07:22 PM Thread Starter
ronjenx
ronjenx's Avatar
You can't go by looks. It's the measurement you got that's important.
If the axial play on the lower ball joint was more than 0.050", it was worn.
post #9 of 26 Old 02-02-2010, 08:01 PM
chickenhawk7
So I was looking for my ball joints. They are close to the battery, right?
chickenhawk7 is offline
post #10 of 26 Old 02-03-2010, 08:30 AM
FatBuoy
FatBuoy's Avatar
Yes, but only on 07s and 08s. In 09 they moved them to the other side.
Black Rubi JKU with a rompin' stompin' 6.1 magnuson supercharged hemi!
FatBuoy is offline
post #11 of 26 Old 02-03-2010, 08:40 AM
Ole Yeller
Ole Yeller's Avatar
2010 JK Wrangler
I think it's actually closer to the muffler bearing on 07 08 and near the blinker fluid on 09 10.
2006 Commander
2000 TJ Sport
My previous Jeeps
post #12 of 26 Old 02-03-2010, 06:14 PM
AlterEgo
Just look for the bat and glove joints. Its right there.
Gary Greenway - KD8NHC
08 4 Door Rubicon
Member of Two Trackers 4wd Club
Great Lakes Four Wheel Drive Association
United Four Wheel Drive Associations
AlterEgo is offline
post #13 of 26 Old 02-03-2010, 08:04 PM
chickenhawk7
See, this is why I just love this forum. Everyone is so helpful. I was thinking it was close to the battery, but started to get a little overwhelmed when trying to locate the muffler bearing. I will find it, just got to keep looking. So the muffler bearing is actually in the same area as the battery, right?
Ronjenx, don't be offended by my stupid humor. It was a good write-up, just havin' fun.
post #14 of 26 Old 02-03-2010, 08:14 PM
Ole Yeller
Ole Yeller's Avatar
2010 JK Wrangler
If you haven't seen it before, KaleCoAuto, Hard to find automotive items! has all those hard to find parts.
2006 Commander
2000 TJ Sport
My previous Jeeps
post #15 of 26 Old 02-03-2010, 08:20 PM Thread Starter
ronjenx
ronjenx's Avatar
No offense taken. I almost contributed to it.
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 10:59 AM
U-Joint and Ball-Joint question gcally TJ Wrangler Technical Forum 5 02-18-2009 10:28 AM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 12:27 AM
Bad ball joint or not? hkiss96 TJ Wrangler Technical Forum 1 08-19-2005 07:00 AM
front wheel problems (u joint, ball joint etc) ohhpe YJ Wrangler Technical Forum 0 06-05-2005 03:40 PM
