Odd- Temp light + Low Tire Press Light - JeepForum.com
post #1 of 7 Old 02-27-2011, 06:56 AM Thread Starter
09Jeep
Iíve come across an issue where sporadically my temp light and low tire pressure lights come on at the same time. They will both appear for 1-4 seconds then go away for several minutes before re-appearing. Iíve had all the required service from the dealership. And just completed, a few months ago, the complete 36K mile service where all the fluids are flushed/replaced. During our short winter here in Texas this would occur only when the heater was on. As long as I was willing to freeze on the way to work I didnít have to deal w/ the warning lights; however yesterday while the temp was in the 80s was the first time the lights came on w/ the a/c on. All the tires are fully aired up and all the fluids are topped off. I flipped the key on a couple of times to see if there was anything on the display that would appear and nothing came up. Ideas?
09Jeep is offline
post #2 of 7 Old 02-27-2011, 09:59 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
First, Welcome to the forum!
Probably have to look at any codes that were generated and might need to reboot the ECM - If that fails might need a reflash at the dealer. The reboot is easy, just disconnect the battery for about 10 to 15 minutes and then reconnect.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 7 Old 02-27-2011, 11:19 AM Thread Starter
09Jeep
Thanks I'll give that a shot!
09Jeep is offline
post #4 of 7 Old 10-05-2013, 05:02 PM
Eplatvoet
Was this ever resolved?
I have the same thing happening occasionally.... It may be related to having the heater on? Anyone else have this happen? Any fixes? Weird...
Eplatvoet is offline
post #5 of 7 Old 10-05-2013, 06:27 PM
VEGASROBBI
I have seen this on several 2008's and 9's. Check tire pressure. When aired up and on the highway tire pressure increases, especially at 80 mph in TX, I was just there.
I aired up in Vegas to 35 psi and by Fort Stockton I was at 41 psi. I find the TPMS and red hot dot illuminate accompanied by a ding.
As usual it's not 100% with the Chrysler can bus but a good place to start.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #6 of 7 Old 11-06-2013, 05:05 PM
Eplatvoet
Okay, that could be it, it tend to overinflate a little because the dial on the compressor is very coarse and difficult to read properly... I will try that, thanks.
post #7 of 7 Old 11-07-2013, 10:16 AM
crlickey
My 08 wrangler does this too. Mine does it regardless of tire pressure and even when i have no sensors in my wheels. Sometimes it will go a month without doing it and sometimes it will do it 15 times within 5 minutes.....
crlickey is offline
CHEAP TJ BRAKE LIGHT MOD for SPARE TIRE LIGHT wheresgeorgenow TJ Wrangler Technical Forum 5 01-01-2012 07:45 AM
Just had the tranny temp light recall done. montero1 JK Wrangler Technical Forum 5 10-18-2010 02:59 PM
ESP LIGHT/ESP BAS Light - after lift and tire upgrade drvnwheel JK Wrangler Technical Forum 7 07-29-2009 08:33 AM
Temp Control Light Replacement?? vfrpilot TJ Wrangler Technical Forum 14 01-31-2009 09:04 PM
Fuel and Temp Gauge Light Out GoPackGo10 YJ Wrangler Technical Forum 8 12-11-2007 07:15 PM
