Odd rattling sound around 2K RPM - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Odd rattling sound around 2K RPM
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiClayton Off Road WJ Long Arm Kits!Clayton Off Road - JK Prototype Gas Tank Skid
Unread 04-13-2014, 03:23 PM   #1
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
Hello all, just trying to find out my strang rattling sound. Its only when im driving and the rpms are at around 2k rpms. It almost sounds like a rock rattling inside a pop can. Nothing seems loose, and its not suspension related cause it doesnt happen over bumps or anything. I would try to get a video but it was really hard to get the sound through the phone. It seems like its somewhere around the center of the jeep, underneath. Any input would be greatly appreciated!
Its a 2008 unlimited 3.8 sahara with 51k miles.
08 JK Sahara | AEV | Rock Krawler | BFGoodrich | Yukon | ARB | Solid | Bushwacker | Yakima | Rigid Industries
MoonyJohn is offline   Reply With Quote
Unread 04-13-2014, 03:27 PM   #2
Jiblet
Originally Posted by MoonyJohn
Hello all, just trying to find out my strang rattling sound. Its only when im driving and the rpms are at around 2k rpms. It almost sounds like a rock rattling inside a pop can. Nothing seems loose, and its not suspension related cause it doesnt happen over bumps or anything. I would try to get a video but it was really hard to get the sound through the phone. It seems like its somewhere around the center of the jeep, underneath. Any input would be greatly appreciated! Its a 2008 unlimited 3.8 sahara with 51k miles.
Sounds like a heat shield is loose somewhere.
Jiblet is offline   Reply With Quote
Unread 04-13-2014, 03:28 PM   #3
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
Ooo, good call. Ill go take a look!
Thankyou
Unread 04-13-2014, 03:44 PM   #4
Mopar Fan
It sounds like the heat shield on the exhaust crossover in front of the transmission crossmember.
Put some hose clamps at the weld connections to verify.
2007 Bright Silver JK Unlimited X
2008 Jeep Green JK Unlimited Sahara
Mopar Fan is offline   Reply With Quote
Unread 04-13-2014, 03:46 PM   #5
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
Wow you guys are good! It was a heat sheild on the passenger side right by the header it looked like, just put a washer and bolt and solved the problem
