OBDII Plug Dead: - Page 2 - JeepForum.com
post #16 of 22 Old 09-14-2010, 04:36 PM Thread Starter
fakrwee
2010 JK Wrangler
Originally Posted by RMiksits View Post
be sure and check all connecters from the plug to the computer.
call superchips before taking it to the dealer.
be sure its the plug and not the flaspaq try a code reader.
Thanks, I tried a scan gauge and that didn't work either. I'll keep checking.
Tom
fakrwee is offline
post #17 of 22 Old 09-14-2010, 04:51 PM
NickSully
2010 JK Wrangler
Have you tried disconnecting the battery for 30 minutes? Maybe some sort of hard reset is in order.
NickSully is offline
post #18 of 22 Old 09-14-2010, 10:35 PM Thread Starter
fakrwee
2010 JK Wrangler
Yea, I left it disconnected a couple of hours, no go. Thanks Sully. Tomorrow I'm going to a mech.
Tom
fakrwee is offline
post #19 of 22 Old 09-14-2010, 10:43 PM
Charles
2017 WK
It obvious that the dirty oil has clogged your OBD II port. You'll have to change the oil yourself.
Charles is offline
post #20 of 22 Old 09-15-2010, 01:13 PM Thread Starter
fakrwee
2010 JK Wrangler
Cute
SOLVED!!!! I did another fuse check and found the culprit. Fuse #30 15AMP Wiper motor Frt. & J1962 Diagnostic Feed fuse. Hope it helps someone in the furure.
Somehow I missed it. All is back to good. Thanks for all the replies.
Tom-Fakrwee
fakrwee is offline
post #21 of 22 Old 09-15-2010, 02:15 PM
Charles
2017 WK
Good info.
Charles is offline
post #22 of 22 Old 05-26-2013, 04:24 PM
maceman
2010 JK Wrangler
Thanks for this post!! I had already re-wired my plug and still nothing...Fuse #30 was a winner!!! Problem Solved!!
Mace
maceman is offline
wheres the OBDII plug in for AEV pro cal? Jodyblip JK Wrangler Technical Forum 3 06-13-2010 11:59 AM
OBDII Dead bosp7 TJ Wrangler Technical Forum 5 01-15-2010 01:13 PM
OBDII sign comes on, charlescho TJ Wrangler Technical Forum 5 10-26-2006 06:35 AM
Need help on OBDII servozn TJ Wrangler Technical Forum 9 07-04-2006 09:02 PM
OBD vs. OBDII scottheath5499 TJ Wrangler Technical Forum 1 04-27-2006 03:02 PM
