OBDII Plug Dead: - JeepForum.com
post #1 of 22 Old 09-12-2010, 07:06 PM Thread Starter
fakrwee
2010 JK Wrangler
OBDII Plug Dead:
2010 Jeep Rubicon, 2 door. Stock with K&N. superchip flaspaq.
Hi guy's, hope someone has an idea what's going on.
Went to return jeep to stock configuration with my superchip and the OBDII plug is dead.
I tried to connect my scan gauge, same results.
Checked the fuses and they are OK. My MIL symbol flashes with the key in on and then stays solid. It's supposed to stay solid.
Any ideas? I have an appointment tomorrow in the dealer. Should I postpone it till I set the JK to stock or take it in?
Thanks
Tom-Fakrwee
fakrwee is offline
post #2 of 22 Old 09-12-2010, 08:06 PM
jeepcache
2010 JK Wrangler
whats the appt for?
jeepcache is offline
post #3 of 22 Old 09-12-2010, 09:18 PM
newjk
no hold off, unless your sure dealer is mod freindly. i hear on this forum, some dealers go out of their way to void warranty. i "think i have read that that there is something in the computer that sets off something when computer retuned." i'm sure others who know exactly what happened will chime in. don't risk warranty just yet.
newjk is offline
post #4 of 22 Old 09-12-2010, 09:33 PM
Warlord2
I would not take it to the dealer if the problem is computer related....an aftermarket program was the first thing they looked for with my stall issue (still not fixed).
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #5 of 22 Old 09-12-2010, 11:09 PM Thread Starter
fakrwee
2010 JK Wrangler
Thanks guy's I kinda figured that. I'll hold off taking it in till I find out what's going on.
Jeepcache, that's the funny part, it's for a free oil change and tire rotation.
Anyone know why the MIL symbol flashes?
Tom
fakrwee is offline
post #6 of 22 Old 09-12-2010, 11:34 PM Thread Starter
fakrwee
2010 JK Wrangler
Thanks guy's. I guess I'll keep looking and see if I can fix it before I go. Hope it's nothing I have to take it in.
Jeepcache, funny thing, it's for a free oil change and tire rotation.
Tom
fakrwee is offline
post #7 of 22 Old 09-13-2010, 12:53 AM
planman
Thanks to all Mod erators
planman's Avatar
It has to be a fuse somewhere.
I am not at home. Otherwise I'd pull out my manual to look for the fuse box info. I believe there is one in the engine bay and one behind the glove box.
planman is offline
post #8 of 22 Old 09-13-2010, 09:55 AM Thread Starter
fakrwee
2010 JK Wrangler
Hey Planman. I took it in and the dealer prefers I return it back to stock before he services it. He showed me a couple of more fuses I should remove.
I can't find the fuse box behind the glove box. Can anyone help me locate it?
Thanks guy's.
Tom
fakrwee is offline
post #9 of 22 Old 09-13-2010, 10:05 AM
ncb
The owners manual will have a section regarding the fuse box locations. I'm not familiar with the locations because I haven't popped any fuses.
ncb is offline
post #10 of 22 Old 09-13-2010, 10:19 AM
newjk
headrush, can we get a little explanation on 07 american unlike 08+ tks
newjk is offline
post #11 of 22 Old 09-13-2010, 10:30 AM
RMiksits
New JK Headrush is not in this topic. Thats in NCB's signature.
Interested in how this gets fixed though?
RMiksits is offline
post #12 of 22 Old 09-13-2010, 12:14 PM
babiehughie
There is only one fuse box - the TIPM (Totally Integrated Power Module) in the engine bay.
babiehughie is offline
post #13 of 22 Old 09-13-2010, 12:33 PM Thread Starter
fakrwee
2010 JK Wrangler
Thanks babiehughie, that's what I thought. I was kinda hoping there was another one.
fakrwee is offline
post #14 of 22 Old 09-13-2010, 11:33 PM Thread Starter
fakrwee
2010 JK Wrangler
Well done just about everything and plug is still dead.
It's also doing the following:
With the key in on position the engine or MIL light comes on.
5. Approximately 15 seconds later, one of two things will
happen:
a. The MIL will flash for about 10 seconds and then
return to being fully illuminated until you turn OFF
the ignition or start the engine. This means that your
vehicle’s OBD II system is not ready and you should
not proceed to the I/M station.
b. The MIL will not flash at all and will remain fully
illuminated until you turn OFF the ignition or start the
engine. This means that your vehicle’s OBD II system
is ready and you can proceed to the I/M station
Mine is doing a. What the hell is going on? I guess I might have to bite the bullet and take it in to the dealer. Dam.
Tom
fakrwee is offline
post #15 of 22 Old 09-14-2010, 12:04 AM
RMiksits
be sure and check all connecters from the plug to the computer.
call superchips before taking it to the dealer.
be sure its the plug and not the flaspaq try a code reader.
RMiksits is offline
wheres the OBDII plug in for AEV pro cal? Jodyblip JK Wrangler Technical Forum 3 06-13-2010 11:59 AM
OBDII Dead bosp7 TJ Wrangler Technical Forum 5 01-15-2010 01:13 PM
OBDII sign comes on, charlescho TJ Wrangler Technical Forum 5 10-26-2006 06:35 AM
Need help on OBDII servozn TJ Wrangler Technical Forum 9 07-04-2006 09:02 PM
OBD vs. OBDII scottheath5499 TJ Wrangler Technical Forum 1 04-27-2006 03:02 PM
