O2 - JeepForum.com
post #1 of 7 Old 02-13-2015, 12:03 AM Thread Starter
Wadiking
O2
Wrangler 2008 Sport
Engine maintenance light is on for a few days then off then on etc. Am told by local Jeep dealers here in Oman its the O2 sensor. However they say I cannot change sensor alone but have to change the Cat plus PCM, whatever that is. Seems a bit excessive to me and it only has 64,000 Kms on clock. Any suggestions?
Wadiking is offline
post #2 of 7 Old 02-13-2015, 07:33 AM
ronjenx
ronjenx's Avatar
What was the code?
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #3 of 7 Old 02-13-2015, 08:25 AM
rich6700
If it's a code for an O2 sensor, just replace the sensor.
rich6700 is offline
post #4 of 7 Old 02-13-2015, 09:18 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
ummmm yes you can just replace the sensor.
Or (since it comes and goes like a loose wire) verify the voltage for the O2 circuits and check all connections first. Since the dealer is suggesting a parts toss approach (and possible that your local laws require a replacement approach?) - I think I would either confirm the wiring and stuff personally and/or go elsewhere for someone who will explain what they doing... and suggesting. I'm not entirely sure what you are up against there in Oman - I am sure your smog system and laws are different than ours! Can you even get your own code reader?
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #5 of 7 Old 02-14-2015, 03:50 AM Thread Starter
Wadiking
O2 sensor
Diagnostics read
PCM PC0032 Active O2 sensor 1/1 Heater Circuit High
Wadiking
Wadiking is offline
post #6 of 7 Old 02-14-2015, 08:01 AM
ronjenx
ronjenx's Avatar
Originally Posted by Wadiking View Post
Diagnostics read
Wadiking
I'm not familiar with PC0032, but here is the data for P0032. Sensor 1/1 is the upper one on the engine's right side.
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
When Monitored:
Battery voltage above 10.6 volts, ASD is powered up, and O2 heater is off.
Set Condition:
The PCM detects that the O2 sensor heater element input is above the maximum acceptable voltage. One trip fault. Three good trips to turn off the MIL.
Possible Causes
O2 1/1 HEATER CONTROL CIRCUIT OPEN
O2 1/1 HEATER GROUND CIRCUIT OPEN
O2 1/1 HEATER CONTROL CIRCUIT SHORTED TO VOLTAGE
1/1 O2 SENSOR
POWERTRAIN CONTROL MODULE (PCM)
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #7 of 7 Old 02-20-2015, 08:47 AM Thread Starter
Wadiking
O2 sensor
All wiring and connections checked out and appears fine. The O2 sensor after Cat is one giving the most spurious readings but the other 3 are not behaving particularly well!! Dealer has now sourced 3 of 4 sensors in Oman and 4th, the miscreant, will be coming in from US.
Took a while for them to admit that sensor replacement is an option before switching out the Cat and /or PCM.
Hopefully with new sensors fitted problem will be resolved at a fraction of first quoted cost.
Wadiking is offline
