now I'm peeved. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > now I'm peeved.
Win a $250 Gift Card to ZoneOffroad.com - 4th of July FaceRuffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-15-2013, 02:31 PM   #1
trw
2011 JK Wrangler
now I'm peeved.
38k miles on my '11 JK and the clutch sounds absolutely horrid.
I've been dealing with a ticking throw out bearing for 2k miles now, but today something down there (either the throw out bearing or pressure plate) started sounding like an old barn door creaking like mad when the pedal is pushed and released.
I got under and pin pointed the noise right at the clutch (away from the slave cylinder) so I'm relieved its not the slave, but this is ridiculous IMO.
My YJ had 120k miles on its original clutch and the disk had tons of life left when I pulled it. what the hell happened Jeep? How'd you go from great factory clutches to pure garbage?
Also, does anyone have clutch kit recommendations? I'm not about to put the factory clutch back in, this thing needs a REAL clutch.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 02:37 PM   #2
DuckRunner09
1989 XJ Cherokee
Yeah I'm not too impressed with the clutch in my 12 either. Just yesterday I noticed a slight ticking sound between gears and since day one from the outside you can hear the darn thing clunk every time I shift. I'm not looking forward to replacing the clutch but I have a feeling it'll have to be done sooner than it really should.
I don't get lost, just temporarily misplaced
'12 JK-built and wrecked
'89 XJ-work in progress
DuckRunner09 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 03:32 PM   #3
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Centerforce?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 05:14 PM   #4
SteveBad
2011 JK Wrangler
If it makes noise when you step on the clutch, then the problem is the pilot bushing.
If it makes noise when you are just sitting at idle with your foot off the clutch, then the problem is the throwout bearing.
Noise from the throwout bearing is not fatal. You could go another 80,000 with nothing more than noise. As long as the clutch isn't slipping, I'd leave it be.
" Leave the gun .... take the cannolis. "
SteveBad is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 08:32 PM   #5
trw
2011 JK Wrangler
It squeals when the pedal is travelling, up or down. It's quiet when the clutch is released, and the pedal held. It very silently ticks when the pedal is released which I already know is the TB.
getting under the Jeep, I can easily tell its coming from the clutch area itself, and not the slave cylinder. I think its either the pressure plate itself (but not knowing to what extent the pressure plate can produce its own noise) or the TB in some weird way that isn't traditional or usual.
Jeep garage:
Unread 07-15-2013, 09:13 PM   #6
Godholio
Originally Posted by RockyClymer View Post
Centerforce?
I love the CFII I installed in my Sting Ray.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is online now   Reply With Quote Quick reply to this message
Unread 07-16-2013, 04:21 PM   #7
DuckRunner09
1989 XJ Cherokee
What would a likely cause be if it has an audible clunk sound every tube I put it in gear and let off the clutch..? Like it's catching real hard unless I ride it super slow out.
I don't think it's my driving skills since all I've ever owned have been manuals but then again this things a full decade newer than anything else I've had.
