Noticing some vibration in my JK..driveshaft? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Noticing some vibration in my JK..driveshaft?
JK Bumper System - Free Shipping + Cash RebateSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 12-29-2009, 01:32 PM   #1
MattJK09
2009 JK Wrangler
I have been noticing some vibration at approx. 55-65 mph, mostly when my RPM's are around 1500. It's almost like a "lugging" vibration and I can feel it in the steering wheel and seat / floor. Is this just the OD lugging at low RPM at these speeds? It goes away when I speed up. I am concerened that I "streesed" my driveshaft when installing / uninstalling my BB twice. When I reinstalled my BB the second time, I really noticed that there were some lines (looked like fuel or some type of fluid lines) that were REALLY stretched to the tightest they could be in order for the axle to get low enough for me to squeeze the coils back in. I have to assume that I had the driveshaft under alot of stress. Is this an issue? I know I'm paranoid, but don't like new vibrations coming from underneath. It's a " wa wa wa wa wa" vibration if that makes any sense...
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline   Reply With Quote
Unread 12-29-2009, 10:36 PM   #2
Avian
I had the same thing, a lugging noise between 50-60 mph that could be felt through the floor, pedals, and wheel as well. Took it to the dealer thinking it was the rear end or t-case....got a new driveshaft. The one they replaced it with looks completely different from the one I had from the factory.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline   Reply With Quote
Unread 12-30-2009, 06:49 AM   #3
MattJK09
2009 JK Wrangler
I wonder if I will get hassled because of my BB lift?
Unread 12-30-2009, 09:20 AM   #4
calemasters
If the differential pinion angle has changed, that could induce a harmonic vibration in the drive-line. Make sure the front and rear differential pinion angles are within specification.
calemasters is offline   Reply With Quote
Unread 12-30-2009, 05:49 PM   #5
MattJK09
2009 JK Wrangler
So is pinion the same as caster? If it is the pinion or caster that is off, wouldn't it vibrate all the time and not just at low rpm's. It goes away when I speed up and it isn't "lugging".
Unread 12-30-2009, 08:03 PM   #6
calemasters
For solid axles, yes, changing the pinion angle does change the caster also. Harmonic vibrations can phase in and out as the rotational speed of the driveshaft changes.
Unread 12-23-2010, 12:14 AM   #7
JMW1191
2009 JK Wrangler
i just installed 37's on my jeep jk... blew out rear most u-joint, thinking it was causing the vibration i replaced it.. and it is still vibrating. it is coming from the rear end at all speeds. the entire jeep vibrates. What could this be? could the 2inch difference from 35's to 37s really make a difference on the pinion angle?
JMW1191 is offline   Reply With Quote
Unread 12-23-2010, 09:16 AM   #8
RockyClymer
RockyClymer's Avatar
If you have a U joint, then you have replaced your rear DS as the stock has two Rzeppa joints which cannot be replaced by themselves. If you have a double cardan rear shaft, then the rear pinion angle MUST be properly set or you will blow the rear joint (most likely anyway) as it is not designed to run at high speed at an improper angle...so, do you have a U joint (double cardon shaft) in the rear? Did you properly set the rear pinion angle (using adj control arms)? If not, then you will need to do it.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 12-23-2010, 01:16 PM   #9
bluegrassguitar
And this is why I've left my JK totally stock. It gets me where I want to go, anyway.
bluegrassguitar is offline   Reply With Quote
Unread 12-23-2010, 05:56 PM   #10
JMW1191
2009 JK Wrangler
i replaced my stock with the rubicon express rear 1310 driveshaft.. sorry should have mentioned that.. took it to the shop today and they told me that all my u joints were blown and the flanges were both so worn that the u joints wouldnt stay put in them... so basically my only choice was to wait to rebuild it or to buy a new one. I am having one overnighted and installed in the morning. Plus all my control arm bushings are shot... i had rubicon express send me a set in october knowing that they would all go eventually.. thanks
