No gauges, wipers and headlights on despite switches are off - Page 3 - JeepForum.com
post #31 of 39 Old 09-28-2013, 07:07 AM
jwcoogan
Same thing just happened to me this morning. All gauges off, wipers and headlights on even though switched off. I switched the headlight switch on and everything came back to normal. 2010 Wrangler Sport wih 48K miles.
jwcoogan is offline
post #32 of 39 Old 07-08-2014, 10:29 AM
tedmorgan
2010 JK Wrangler
Has there ever been a resolution discovered for this? I have the exact same issue right now with my 2010 Wrangler Sport X
tedmorgan is offline
post #33 of 39 Old 08-21-2014, 08:15 AM
dvanloon
2010 JK Wrangler
No gauges, wipers stuck on, can't get out of park
Left jeep (soft-top) in torrential downpour for about 24 hours and thats when i had these problems. (also, for note, radio DID work as well as hazards, but no turn signal and no gauges at all, wipers stuck on)
Went and followed other advice and just reset by unhooking battery and hooking back up. Carried a screwdriver with me for about a day of doing this (as soon as I turn jeep off and left for 5 min., it would revert to no gauges, windshield wipers on, can't get out of park, etc.)
That night and next day I let sit in garage to dry out, and everything is fine again. Somehow, condensation got into the wiring in that rainstorm, and cause all that haywire crap to go on. Not feeling too great that my Jeep has this achilles heel, but live and learn!
dvanloon is offline
post #34 of 39 Old 12-08-2015, 09:06 PM
Erickar88
Similar problem
Same issue, only my wipers were not on: no gauges, headlights won't turn off, radio worked, car charger(plugged into the socket) worked, smh... just weird. Disconnecting the positive side of my battery for a min or so worked to get everything working again, but every time I turn off the car to run in somewhere the same thing happened. Took it to a shop and they said it was my TIPM. That didn't make sense so took it to the dealership and they said (amongst other things) that it was my instrumental cluster. Changed out the cluster and everything is back to normal. Hope this helps someone.
Erickar88 is offline
post #35 of 39 Old 03-21-2016, 10:44 AM
Ruselton
2011 JK Wrangler
Did anyone find the solution for this problem 2011 just did it at 62k miles
Ruselton is offline
post #36 of 39 Old 03-21-2016, 11:38 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
My 11 did this twice over 30K miles, did not do it for 20K some miles. My 12 has done it once (18K on the clock now). Just reset and go worked for me.
Now however I have a bigger problem on the 11. Every time I turn the high beams on with the engine running the entire bus goes wacky (head, tail and turn lamps flickering, relays in the TIPM cycling like mad, no gauges and all lights on in the dash with "no bus" message on dash - and engine continues to run after key off AND OUT.
I had a voltage issue and I think a module is now trying to operate under the code of a corrupt file.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #37 of 39 Old 06-09-2016, 01:46 PM
HodgyUSMC
I had this same issue with the wipers staying off, cluster out, blinkers out, headlights on. Auto zone says the battery is fine. Grounds looked good to me but I'm not very good with electrical stuff. I bring it to a mechanic and they say it's the TIPM and send me to the dealership. Dealership wants to take me for $1200 so I buy one for $600 (150 core) from Mopar. Put it in, do the 12 second key dance, now the wipers are going but everything else is the same. I bring it to the dealership to get them to flash it with their computer. It's showing it's a diesel so they think it's the wrong part. I convince them that it's the right part. Now they're saying this new TIPM I put in is bad. Should I try to get it replaced? Is it likely that they sent me a bad one and does that jive with these symptoms? Maybe I should take this to mean that it wasn't the TIPM after all?
HodgyUSMC is offline
post #38 of 39 Old 05-14-2017, 03:11 PM
ewhite123456
Same issue
Same issue with my 2011 sahara today. Car starts, wipers going mad, lights on, no idiot lights. Can not engage transmission (auto) Tried restarting and zilch. Turned the headlight switch and everything started working properly. Got lucky. This has been the worst vehicle I ever had. Since new it constantly goes in the shop for something else going wrong. "Mygig" software is the worst I have ever seen.
ewhite123456 is offline
post #39 of 39 Old 05-15-2017, 08:34 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hi ewhite123456,
Sorry to hear about your ongoing concerns with your vehicle. In the future if you decide to visit your local dealership for further diagnosis don't hesitate to PM our page with your VIN for additional assistance if needed.
Andrea
Jeep Social Care Specialist
JeepCares is online now
in-cab electrical ALL dead, gauges, lights and switches whatevah TJ Wrangler Technical Forum 5 08-04-2010 09:04 PM
Instrument Gauges flicker while windshield wipers are going. hillie4life YJ Wrangler Technical Forum 3 10-30-2009 10:36 AM
Headlights don't come up but wipers do! Help! Josh1466 TJ Wrangler Technical Forum 9 03-30-2009 09:46 PM
Wipers turn on when they want/dim out headlights when they do?? Nate M YJ Wrangler Technical Forum 2 12-31-2007 03:53 PM
