No 4low ...fixed! - JeepForum.com
post #1 of 2 Old 08-11-2009, 02:05 AM Thread Starter
1222
RIP John
1222's Avatar
No 4low ...fixed!
The other day while off-roading I needed to use 4low to get out of a desert wash. It was no big deal, just too soft without using low. When I went to engage low it wouldn’t go. After several attempts I gave up. It worked fine earlier in the day. Anyway, to make a long story short, it turned out to be a small rock that had jammed itself between the shift fork and case. The only way I found it was using a telescoping mirror. I also noticed that the cable end was missing the clip to hold it on. I’m not sure how long it’s been that way because it just seems to float on it. Other than the rock, has anyone ever lost the clip to the cable end?
(2011-2016)
1222 is offline
post #2 of 2 Old 08-11-2009, 04:02 AM
LHS-Cowboy
DETN8R
LHS-Cowboy's Avatar
Wow, good eye.
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power
Installed:
R.E. Modified 3.5 Super Flex Kit to 4+/Ft. & Rr. U-joint driveshafts/Full Traction Rear Adj. Trackbar/Custom Ft. Heim Joint Adj. Trackbar/Rancho 9000XL shocks/Yukon 4.88 Gears & Superior Rear Axle Shafts/37" Pitt Bull Rockers on Custom Allied Beadlocks/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Rear Bumper/Custom Trans. Crossmember and Skid/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant HP/Cobra 75 WS XT C.B./Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on Custom Rear Swing Away Carrier/...
____oooo
[ l_,[____],
l---L -[
OlllllllO]
( )_) ( )_)--)_)
LHS-Cowboy is offline
4hi vs. 4low in mud mpgrunt2002 YJ Wrangler Technical Forum 15 02-20-2009 08:16 AM
Where did 4low go? twistedfred87 YJ Wrangler Technical Forum 5 03-15-2008 01:26 PM
Will Not Shift into 4low XtremeJeep TJ Wrangler Technical Forum 6 04-04-2007 07:13 PM
SYE in 4Low method84 TJ Wrangler Technical Forum 2 04-16-2006 12:29 PM
4hi 4low Joeys97TJ TJ Wrangler Technical Forum 20 05-02-2005 11:07 AM
