Next stage in build, 40s on a 3" OME LT lift, 1" BL, & flat flares - Page 6 - JeepForum.com
post #76 of 77 Old 08-31-2013, 02:43 PM Thread Starter
planman
Thanks to all Mod erators
planman's Avatar
Thanks guys.
I will do some updates. I've made some changes during the last year.
Regarding balancing 40s. The Xterrains and Walker Evans beadlocks didn't require much weight. So, when I swapped the tires over to ATX Slab beadlocks with a 5x5.5" bolt pattern to run on my Dana 60s, I didn't have them balanced. Between 72-75 mph is when I start to notice that they are not balanced. For me, that is fine. When I go very long distances, I trailer it anyway.
Now, on a less expensive wheel, no balancing could be a bigger problem. Also, other tire brands sometimes require more weight. I don't think a Super Swamper or Goodyear MTR 40" tire on a steel wheel would be smooth at 70 mph with no balancing.
planman is offline
post #77 of 77 Old 08-31-2013, 10:55 PM
zjilla
ok thanks. i was just wondering bc ive heard diffrent things on larger tires like that.
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
40" tires , JK Wrangler , lift , minimum lift , wrangler
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 09:44 PM
Would 35" Tires & Bushwacker Flat Flares rub w/o a lift? JKashat JK Wrangler Technical Forum 45 05-01-2014 12:12 PM
Poly Performance Jeep Jk 4" Stage 3 lift versus AEV / Nth degree 3.5 " Premium lift TDmaster JK Wrangler Technical Forum 20 02-08-2013 02:43 PM
What "stage" are you in your build? Me, I'm at 0. Neeco TJ Wrangler Technical Forum 49 10-01-2009 09:00 AM
Trimming rear plastic flares for more clearance and "Flat Look" TexanTJ TJ Wrangler Technical Forum 9 06-18-2009 04:11 PM
