newbie lift questions - JeepForum.com
post #1 of 4 Old 12-14-2013, 08:41 PM Thread Starter
krlewis
have a 08 wrangler 2dr soft top 6speed v6
what is the best way to lift. would like about a 2" lift and be able to run
33's on it.
is a body boost the same as a budget boost will the drive shift ect need to be
changed/cut for a 2" lift
no hard core off roading here on the beach and some snow
tks for in info
krlewis is offline
post #2 of 4 Old 12-14-2013, 08:46 PM
Tragyn
2011 JK Wrangler
Should run 33's with backspacing no lift required.
Bunch of 2/2.5" kits available. Shouldn't need to change anything if you're not lifting suspension.
Tragyn is offline
post #3 of 4 Old 12-14-2013, 08:48 PM
buns79
A body lift is not the same as a budget lift but go with a budget lift which will consist of some spacers and either shocks or shock extensions... But 33 will fit as it sits now!
2013 jku. Manual trans, 2.5in teraflex lift with 1in spacers,35in duratracs, soft top, ace rear bumper, poison Spyder front bumper, smittybuilt winch, 4:88s with eaton elockers front and rear. Spod, rigid LEDs, rugged ridge snorkel and the list goes on and on... 0lllllll0
buns79 is offline
post #4 of 4 Old 12-14-2013, 10:18 PM
1222
RIP John
1222's Avatar
Take a look at this sticky, it will answer a lot of the questions you’ll have concerning lifts and whatnot.
EDIT: Welcome to the forum.
1222 is offline
