new wheel question - JeepForum.com
post #1 of 8 Old 08-10-2010, 10:43 PM Thread Starter
tango4807
2010 JK Wrangler
new wheel question
I am going to purchase new wheels for a 2010 rubicon 17" they are 5x 5 right? Want to make sure before buying
tango4807 is offline
post #2 of 8 Old 08-10-2010, 11:12 PM Thread Starter
tango4807
2010 JK Wrangler
i'm going with 17x8 pro comp xtreme 7089 flat black i shouldn't need spacers since that is the size on now. i am going to keep the stock tires till they wear down 5 on 5 bolt pattern correct
post #3 of 8 Old 08-10-2010, 11:58 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Yes they are 5 x 5 bolt patern and you want to have 4" or less back-space.
Jim
JLC08JK is offline
post #4 of 8 Old 12-03-2010, 10:55 PM
JocoRacing
2011 JK Wrangler
probably ben asked a billion times, but i cant find a solid answer, with the 4 1/2" back spacing you dont need wheel spacers right?
JocoRacing is offline
post #5 of 8 Old 12-03-2010, 11:46 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Correct - if you get around 4.5 or 4 inch BS - then no spacers are needed for up to a 35x12.5 or a 37x about the same...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #6 of 8 Old 12-04-2010, 08:37 AM
JocoRacing
2011 JK Wrangler
thanks a ton
post #7 of 8 Old 12-04-2010, 01:53 PM
Robbish87
2010 JK Wrangler
Would a 35x12.50R17 work on a wheel with around 4.75bs?
Robbish87 is offline
post #8 of 8 Old 12-04-2010, 02:40 PM
ncb
I have the same wheels with 4.5" backspacing and they fit perfect. Go for it.
ncb is offline
Gear Question and Tire/Wheel Question brjeep TJ Wrangler Technical Forum 3 01-19-2010 09:09 AM
wheel question danielp YJ Wrangler Technical Forum 1 04-30-2007 07:24 PM
TJ Wheel Question Skeezer TJ Wrangler Technical Forum 4 08-03-2006 05:39 PM
Wheel question? SteelBlueTJ TJ Wrangler Technical Forum 1 12-27-2004 06:46 PM
Wheel Question ToTaLeD YJ Wrangler Technical Forum 4 11-23-2004 06:46 PM
