Quantcast new tires for stock 18's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > new tires for stock 18's
Old 12-22-2008, 12:06 AM   #1
taj8250
Okay so I have done some searchin, but I still have some questions about the stock Sahara 18's. I like the stock wheels and at this point I am not looking to lift except for maybe the body lift. Point me in the right direction for the right tires to look for. The stock tires look too soccer momish. I want something a little more capable and something that looks like it belongs on a Jeep.
I can't find anything in the stock 255/70/18 size, so what size should I look for that will keep me away from the suspension right now? I'll do the spacers and BL if I need too. Thanks in advance y'all.
taj8250 is offline   Reply With Quote
Old 12-22-2008, 10:18 AM   #2
asknight
DW victim # 7,471,643
asknight's Avatar
What's most important, looks or performance?
Looks -
Nitto Dune Grappler LT285/65R18 32.5" OK for stock suspension
Performance -
Nitto Terra Grappler LT285/65R18 32.5"
BFG TA-KO LT285/65R18 32.6"
4wd.com has all of those but you'd likely be better served by a local tire shop.
asknight is offline   Reply With Quote
Old 12-22-2008, 10:41 AM   #3
Prot
Gold Member
Prot's Avatar
Cheapest route is to buy some rubicon wheels/tires. You can find them with hardly any miles on them for around $600 for all five if you look around. They will have the added benefit of being cheaper to buy tires for when they wear out and more choices are available.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/
http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html
Prot is offline   Reply With Quote
Old 12-22-2008, 11:05 AM   #4
Hilldweller
SE Expedition Society
Hilldweller's Avatar
2011
Summit Mud Dawgs in a 275/65-18 will fit with no mods and are about $200 each.
They're also closer to a real 32" tire rather than the stock Dueler which is about 31.5" or so...
Safety fast, Bill
I have never been lost, but I will admit to being confused for several weeks.
I was happy in the midst of dangers and inconveniences.
Daniel Boone
Overland Rallies & Workshops ** Overland Expo 2012
Hilldweller is offline   Reply With Quote
Old 12-22-2008, 08:30 PM   #5
taj8250
Thanks for the suggestions. I also found this website which has been real helpful
http://www.miata.net/garage/tirecalc.html
So far I like the Nitto Terra Grapplers, General Tire Grabbers,Yokohama Geolanders, and **** Cepek Fun Country. Any thoughts? Experiences good or bad?
Are 305/60/18's too wide for stock setup? I think I read in the FAQ that 12.5 will fit but is it pushin the limits? Do you just need the spacers?
Old 12-22-2008, 08:38 PM   #6
That1guy
2007 WK
My friend uses the fcII's one both his jeep. They are a great DD/weekend tire. They wear nice and look agressive, but isnt a full mud tire.
My dad has the grabbers on his yukon and they are nice.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline   Reply With Quote
Old 12-22-2008, 08:57 PM   #7
CGScotty
Straight And To The Point
CGScotty's Avatar
You are correct. Mine are 35's and went on even better with the DC Torque's. They run awsome in the snow and all other junk you wanna run um thru. They are also very quiet. I know they are there with noise but nothing to bad.
¡ɟlǝsʇı ʇnɔ plnoʍ ʇı uǝɥʇ˙˙˙˙˙oɯǝ sɐʍ ssɐɹƃ ʎɯ ɥsıʍ ı
NRA Patron Member
CGScotty is offline   Reply With Quote
Old 12-22-2008, 10:08 PM   #8
taj8250
Your Jeep looks very good. What's the full size on the tires you're running and what kinda lift do you have?
Old 12-24-2008, 09:34 AM   #9
Hilldweller
2011
On the Sahara, all that will fit with a lift, spacers, or a different wheel are:
stock 255/70-18
a little taller & wider 265/70-18 ---- about 2% speedo & odo error
a little wider 275/65-18
with spacers you can put on wider.
Safety fast, Bill
Daniel Boone
Old 12-24-2008, 10:41 AM   #10
CGScotty
CGScotty's Avatar
3 in teraflex and 35X12.50R17LT on the tires. They are DC Torque wheels.
NRA Patron Member
Old 12-24-2008, 11:33 AM   #11
BadHammers
Sorry for the newbie question, but are the Rubicon 17" wheel & 255/75/17 tire combo a direct bolt-on replacement for the 18" sahara wheels? Any rubbing with the more aggressive tread or backspacing issues?
BadHammers is offline   Reply With Quote
Old 12-24-2008, 12:15 PM   #12
TNJeepMan
I really like the Nitto Terra Grapplers for an All-Terrain tire, we have had great luck with them, for Muds I like the Toyo Mud Terrains.
08 Rubicon Unlimited: Auto, Power, MyGig, Rough Country 2.2 Lift, RC Dual Stabilizer, 35" Toyo Mud Terrains, 18" Black Widow Wheels, Shrockworks Rock Sliders, more to come....
79 CJ5 Renegade: V8, Muds, and a little rust
TNJeepMan is offline   Reply With Quote
Old 12-24-2008, 02:35 PM   #13
Prot
Gold Member
Prot's Avatar
Here's mine on BFG AT TA / KO. These are 315/70-17.
Old 12-24-2008, 02:39 PM   #14
bcoffman2@allte
I like the 18" and tires are only about 25 more each.
Louisville Cardinals!!!
bcoffman2@allte is offline   Reply With Quote
Old 12-24-2008, 07:19 PM   #15
Prot
Gold Member
Prot's Avatar
Bolts right on with no problems or modification. Wheels and tires from an X, Sahara, Rubicon, 2 door, 4 door, are all interchangeable and do not require anything except an adjustment to the speedometer / odometer. In the case of going from Sahara to Rubicon's, no speedometer/ odometer calibration is even necessary as they are virtually the same circumference.
Glock Forum
