New tires and lift - Page 2 - JeepForum.com
post #16 of 24 Old 01-18-2014, 12:47 PM Thread Starter
crumpcl
Also
Guys this is the first time i have ever used a forum or communicated on the web so thanks for your help.
crumpcl is offline
post #17 of 24 Old 01-18-2014, 01:09 PM Thread Starter
crumpcl
Ball joints
What is the best way to check the ball joints to see if there worn out? Just jack it up and look for play? And if there worn what is the best route or brand to replace them ?
crumpcl is offline
post #18 of 24 Old 01-18-2014, 03:29 PM
JTPhoto
JTPhoto's Avatar
Jack up one front wheel about a n inch or 2 off the ground.
Place a ply bar under the tire and try and lift the tire even higher off the ground with the bar. If there is movement in the ball joints they should be replaced.
You may need an assistant to watch for play in the balljoints as you lift.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #19 of 24 Old 01-18-2014, 07:28 PM
SubAtomicGenius
2011 JK Wrangler
Spacers don't allow for correction of caster angles, no repositioning/recentering axle assemblies in the wheel wells or side-to-side, no extended brake lines... just asking for trouble IMHO. I'm ok with spacers around 1.5" to even 2" - but 3" is way out IMHO.
A 3" lift with adjustable control arms, brake line extensions, bumpstops, adjustable front trackbar and rear relocation bracket costs around $2500. That doesn't even include installation costs or a new driveshaft - which will also be needed sooner or later. However, money spent on a proper 3" lift will drive better than stock - even with big mud tires (set at proper pressure). Oh, and avoid RC.
SubAtomicGenius is offline
post #20 of 24 Old 01-19-2014, 01:28 AM
HOKIES2010
2011 JK Wrangler
You could spent that much and not get any control arms from AEV
My Build
Couldn't have done it without
HOKIES2010 is offline
post #21 of 24 Old 01-19-2014, 05:25 AM
TheBoss
No he could have spent $1000. for the AEV dualsport lift and added the control arm drop brackets and been fine for quite a while. Unless you're dragging your Jeep through some serious rock gardens the drop brackets will work fine. That is NOT to say AEV is a be all end all all inclusive lift because it is not. Without spending upwards of $3000 you're not going to get everything you need.
TheBoss is offline
post #22 of 24 Old 01-19-2014, 05:41 AM
HOKIES2010
2011 JK Wrangler
The 3.5 Dual Sport with shocks comes close to 2200? Not to mention the new driveshafts. Add one driveshaft and there is your 2500 mark. Without control arms.
I do agree. The right parts cost money
Edit: And not saying he needs 3.5, just closest to the numbers that have thrown around. Actually sounds like he would be better off with a 2.5. But who wants to go down.
My Build
post #23 of 24 Old 01-19-2014, 06:05 AM
TheBoss
Yeah I hear ya, it's like the same topic with a different op every week. Search and search the info is out there.I think we have good intentions but get frustrated hearing the same issues.
TheBoss is offline
post #24 of 24 Old 01-20-2014, 08:56 AM
propped1
Originally Posted by crumpcl View Post
New to jeep forum, just got a 2008 wrangler x put 17" x 9" rims with 285/70/17 at tires and 3" lift. Jeep doesnt drive near as well as ugly stock tires and rims. Jeep has 60,000 miles so i dont think anything is worn out. Anyone have advice or is it completly normal for the steering to get worse? It's like driving in high winds all the time.
Honestly what I would do, is take the spacers and brackets off and return it to stock. If you like the driveability, then drive it like that. Those tires will fit. I've had 295/75/17s on my stock suspension and PSC Crusher flares.
Once you want to go bigger, lift it the right way. At 60K the best thing you could do now is replace the Ball joints. From what I've heard and my own experience, they are done usually before 60K and can cause all kind of issues.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
