New tires and lift - JeepForum.com
post #1 of 24 Old 01-15-2014, 02:39 PM Thread Starter
crumpcl
New tires and lift
New to jeep forum, just got a 2008 wrangler x put 17" x 9" rims with 285/70/17 at tires and 3" lift. Jeep doesnt drive near as well as ugly stock tires and rims. Jeep has 60,000 miles so i dont think anything is worn out. Anyone have advice or is it completly normal for the steering to get worse? It's like driving in high winds all the time.
crumpcl is offline
post #2 of 24 Old 01-15-2014, 02:43 PM
Tragyn
2011 JK Wrangler
Well...which lift? Tires? What else did you change?
Tragyn is offline
post #3 of 24 Old 01-15-2014, 02:47 PM
ferninaz
ferninaz's Avatar
The entire steering system is probably worn out and thats why it was traded in. You should trade it for a new one, then get a lift kit for that one and when the steering goes to crap, trade it for another one. Without knowing what kind of lift kit you have it is impossible to answer your question seriously. You altered the steering when you lifted it and if you didnt fix the steering geometry than you messed up the steering. Inexpensive lifts will not make driving more enjoyable, but they will help you spend more time in the garage trying to figure out why you have crap steering.
ferninaz is offline
post #4 of 24 Old 01-15-2014, 03:15 PM
222Doc
222Doc's Avatar
what are you running for PSI. most people over inflate tires once they change to big wide tires. Are your tires E rated? If so then much of the ride is from using a f350 tire on 1/2 ton.
None of that applies then it may well be the lift and its flaws and or worn parts.
Example stock mine was 37psi on the stock 32ish.
35x12.5x15 on a 15x8 27psi max on the road. if i ran the tires C rated max of 35 i would bounce across the highway.
222Doc is offline
post #5 of 24 Old 01-15-2014, 11:03 PM
HOKIES2010
2011 JK Wrangler
Again type of lift, what stock components were kept, who did your alignment, are your tires over inflated. Alot of the little things can change how your jeep drives.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #6 of 24 Old 01-16-2014, 09:16 AM Thread Starter
crumpcl
Modifications
The Lift is a 3" Rough Country, just spacers over the springs and shock mount ext. Tires are Nitto Terra Grappler 285/70/17 running @35 psi. I'm taking it for a front end alignment tomorrow so that may help. I guess some busings could be worn at 60K, Iw was a daily driver and i dont think it has ever seen the dirt untile i got it. Thanks for all the responses. I just read the stiffen up steering post and i'm pretty sure where talking about the same issue.
crumpcl is offline
post #7 of 24 Old 01-16-2014, 01:57 PM
Tragyn
2011 JK Wrangler
Well that's a pretty poor way to lift a vehicle. I see no reason why it would handle better than it is.
Tragyn is offline
post #8 of 24 Old 01-16-2014, 02:51 PM
JTPhoto
JTPhoto's Avatar
Agreed it takes more parts then spacers and shock extensions to properly lift 3" and have it ride properly. Also drop your tire pressure down to about 30psi.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is online now
post #9 of 24 Old 01-16-2014, 03:33 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
RC lift tells me all I need to know. Until you do a "proper" lift your drive is what it is.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #10 of 24 Old 01-17-2014, 03:05 PM Thread Starter
crumpcl
same stuff
Took it to get the front end aligned, tie rod end threads are frozen, toe end is out and camfer( I think that's what it's called is off a bit). Putting some knocker loose on it or heat and will be able get it free. Is there a place on the site that shows all the components of the front end ? may need to order some new parts and if I do what would be some good upgrades to the steering instead of putting stock rod ends, bar ect. Thanks in advance for serious help.
crumpcl is offline
post #11 of 24 Old 01-17-2014, 04:11 PM
TheBoss
You're better off ordering an aftermarket tie rod with adjustable heavy duty ends. Your stock unit is only adjustable on one end as you may or may not know. It's camber your referring to and may be due to a worn ball joint which the JK is known to eat stock units as well.
TheBoss is offline
post #12 of 24 Old 01-18-2014, 06:33 AM Thread Starter
crumpcl
Tie rod and ends
Yea I noticed it was only adj. on one side. Who makes a good aftermarket ? Is it better to have the adj. on both ends? What about replacing the ball joints as well?
crumpcl is offline
post #13 of 24 Old 01-18-2014, 06:46 AM
TheBoss
Synergy makes a stout replacement tie rod with greasable ends they also make replacement ball joints check out their site. There are a few vendors here that offer discounts to forum members so you will save some cash there.
TheBoss is offline
post #14 of 24 Old 01-18-2014, 07:21 AM
Butterjeep
2015 WK
The way your Jeep is lifted is not the best way. 3 inches changes the geometry quite a bit and your Jeep will be plagued with issues as you continue to drive it. It's expensive to lift it 3 inches. Also, a 285/70/17 is about a 33 inch tire which can fit on a stock height Jeep with properly spaced wheels.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #15 of 24 Old 01-18-2014, 12:44 PM Thread Starter
crumpcl
Butter jeep I guess ur saying take the lift off if it continues to be flighty and I will. Thanks boss for ur help. I took the rod and ends off today and heated them to get them loose then I drilled and put grease fittings in. So they can align it next week. I'll replace with a better tie rod if necessary. I ran across a site that showed all of the front end parts but can't find it now so if any one knows of it that would help. I don't know if this jeep came from up north or what but the threads on everything under it are pretty rusted! No dirt just frozen nuts. Thanks for y'all's help
crumpcl is offline
