New springs? - JeepForum.com
post #1 of 39 Old 10-14-2013, 04:38 PM Thread Starter
orangera1n
2009 JK Wrangler
New springs?
So I took my jeep to Firestone to get an oil change and they did a free checkup... After 8 hours of waiting the manager called me over and told me he had to show me something. He took me into the garage and showed me my jeep's springs. (I believe I have a 2.5 inch lift, teraflex). He told me that I have a lift and that the stock coil springs are still on the car and are way to loose. He then demastrated how lose by lifting the car up off the ground and taking the rear cool springs off with one hand.
Could this be bad?
The manager stated that it could fly off if I hit a bump.
I also noticed that my friends lifted rubicon 2 door has a 2.5 inch lift and is wayyyy softer on hitting bumps offroad. My suspension feels hard, could this be why?
And should I buy new coil springs?
orangera1n is offline
post #2 of 39 Old 10-14-2013, 04:46 PM
JoonHoss
2011 JK Wrangler
It took them 8 hours to check your oil and inspect your vehicle???
I don't trust those types of shops. No way, no how.
So, do you have a TF budget boost/ leveling kit then?
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #3 of 39 Old 10-14-2013, 04:49 PM
ncb
Sounds like you have enough droop that the springs are unseating. Maybe the shocks are too long for the lift amount.
ncb is offline
post #4 of 39 Old 10-14-2013, 04:55 PM
COLOUXJ
2010 JK Wrangler
You say you have a 2.5" lift. Is that a spacer lift or a spring lift? If its spacer it does not surprise me. Your shocks are too long. If its a spring lift something is fishy. I have to detach my shocks, trackbar and even sometimes lower CA's to get my springs out.
COLOUXJ is offline
post #5 of 39 Old 10-14-2013, 04:59 PM Thread Starter
orangera1n
2009 JK Wrangler
It's not a spacer lift and I have teraflex 9550's.
Online they say they are rated for 6inch lifts???
And I'll upload photos when I get home.
Can anyone upload a picture of a long arm vs a short arm?
post #6 of 39 Old 10-14-2013, 05:00 PM
ncb
Shocks for 6" of lift with 2.5" springs is no bueno.
ncb is offline
post #7 of 39 Old 10-14-2013, 05:05 PM
brianjw
If you have a 2.5" lift with 6" lift shocks, you're probably bottoming the shocks out off road and then the springs unseat because the shocks are too long. No surprise.
brianjw is offline
post #8 of 39 Old 10-14-2013, 05:08 PM Thread Starter
orangera1n
2009 JK Wrangler
Can someone please upload those photos? Thanks
post #9 of 39 Old 10-14-2013, 05:32 PM
SLADE
That guy is an idiot. They won't fall out if you hit a bump.
Put a limiting strap on it if your worried about it.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #10 of 39 Old 10-14-2013, 05:51 PM Thread Starter
orangera1n
2009 JK Wrangler
But could I just put bigger springs on for a larger lift?
post #11 of 39 Old 10-14-2013, 05:55 PM
SLADE
You could get a dual rate or progressive coil spring that is longer when unsprung but maintains the same ride height/lift you have now.
Synergy, Rock Krawler, and Metal Cloak are 3 to look into.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #12 of 39 Old 10-14-2013, 06:02 PM Thread Starter
orangera1n
2009 JK Wrangler
What if I want a larger lift? :P
And how much would long arms cost if I didn't have them already?
post #13 of 39 Old 10-14-2013, 06:03 PM
brianjw
Depends on the company. Also factor in front and rear driveshafts, among a BUNCH of other expensive stuff.
brianjw is offline
post #14 of 39 Old 10-14-2013, 06:04 PM Thread Starter
orangera1n
2009 JK Wrangler
Well what would I need to achieve higher lift?
post #15 of 39 Old 10-14-2013, 06:12 PM
COLOUXJ
2010 JK Wrangler
Completely depends on what you have. Stop asking questions without providing information. Do you research and you will get 99% of all your questions answered. You say in the first post that you might have a 2" lift, but in your profile you say 4".
COLOUXJ is offline
coil , jeep , spring
