New Rubicon Owner.... Couple ?'s - Page 2 - JeepForum.com
post #16 of 16 Old 06-16-2010, 05:41 PM
Charles
2017 WK
Premium fuel is for high compression engines. Premium fuel detonates at a higher temperature. A higher compression engine compresses the fuel air mixture more before the spark plug sparks. When things are compressed they heat up. If you compress an air fuel mixture enough it will get hot enough to detonate before the the spark goes off causing pre-ignition. So, now you have an explosion in the combustion chamber before the piston was in the correct spot. Our engines are not high compression engines and therefore will see no benefit from a high octane gasoline. Another misnomer is that premium gas has more energy per unit... it does not.
Charles is offline
new JK owner, couple questions Ebunny07 JK Wrangler Technical Forum 9 09-01-2009 06:45 PM
new tj owner with a couple of questions fourwheelerjeff TJ Wrangler Technical Forum 4 08-31-2007 07:42 PM
New TJ owner....got a couple questions... watts TJ Wrangler Technical Forum 6 10-17-2006 08:20 AM
Couple questions for new YJ owner BlackRio95 YJ Wrangler Technical Forum 4 05-07-2006 07:31 PM
New YJ Owner, couple of Q's jbrx7 YJ Wrangler Technical Forum 4 07-07-2004 08:11 PM
