New rear rotors and pads needed at 17K??? - JeepForum.com
post #1 of 19 Old 12-23-2013, 01:11 AM Thread Starter
Dead-On
So I started hearing that tell tale sound that sensors make when the pads are worn and I took my JKU into my regular mechanic. He said the rear pads are shot and I need new rotors. They are pretty torn up and can't be turned. My inspection is due this month also and he said he would let it slide till the salt & cinder season is over. So he put a sticker on it. Now I have a couple concerns. 17K seems a little soon to be replacing rear rotors. Also the sensors did not give much of a warning. So here are my questions...
Are the Stock parts junk?
Is there a better rotor & pad I can buy in March that is more durable than these?
I'm a little disappointed I needed rear rotors at 17K.
Dead-On is offline
post #2 of 19 Old 12-23-2013, 08:13 AM
4x4jkx
The rear pads are notorious for needing replacement before the fronts, jks have a programmed rear brake bias. 17k still seems a little early. I would get a second opinion on the rotors, unless you have been running with a lot of mud caked on them your shouldn't need to replace them this early.
If they are shot I know ebc makes good brakes and pads.
4x4jkx is offline
post #3 of 19 Old 12-23-2013, 08:39 AM
ronjenx
ronjenx's Avatar
Brakes and clutches are two things whose longevity is determined mostly by the driver. That's the main reason they are covered for only 12 months or 12,000 miles.
I got over 50,000 miles out of the rear pads, and the front pads are no where near worn out. So I would say the OEM parts are not junk.
ronjenx is online now
post #4 of 19 Old 12-23-2013, 09:32 PM
Butterjeep
2015 WK
On a JK the rears tend to wear quicker but 17k seems very quick. What is your driving style? I like to have fun on snow and ice and I feel the rear brakes "pulling" me back into a straight line but I don't do it all the time, but I know it's stuff like this that probably wears them out quick.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #5 of 19 Old 12-23-2013, 09:43 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Driver bias is the main cause of early brake failure IMO. I just put new rotors/pads on my 08 at about 70,000 miles. The rears were worn way down, the fronts, maybe half worn....I have ridden as a passanger with several JK auto folks, and they seem to ride the brakes IMO...not good from my perspective, like a clutch, get on it or get off it, don't ride it.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #6 of 19 Old 12-24-2013, 01:19 AM Thread Starter
Dead-On
Well I don't drive like a grandma but I also don't drive like a jerk or tailgate etc... It's an automatic and not a manual. I live in a very hilly and curvy part of PA and drive a lot of dirt roads. I do keep the wheels free of mud and snow. I trust my mechanic and I checked it myself. The rotors are pretty chewed up evenly in the rear on both sides. The sensors did not give me much warning at all.
Dead-On is offline
post #7 of 19 Old 12-24-2013, 02:26 AM
HOKIES2010
2011 JK Wrangler
Have 36k on my pads and rotars. I think it has to do wth me engine braking with the manual. I have seen this alot but can't remember if it was mostly in autos or not.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #8 of 19 Old 12-24-2013, 02:26 AM
HOKIES2010
2011 JK Wrangler
You aren't lying about the roads up there. I graduated from Uniontown and lived up your way myself.
My Build
post #9 of 19 Old 12-24-2013, 09:39 AM
zjilla
What size tires are u running? And for how long. I ran 33s and then 35s and had to change mine at 25k miles
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #10 of 19 Old 12-24-2013, 09:41 AM
HOKIES2010
2011 JK Wrangler
OP is running 255/75/R17s and I have 37 x 12.50 R17s
My Build
post #11 of 19 Old 12-24-2013, 09:48 AM Thread Starter
Dead-On
Stock BFG Mud-Terrain T/A KM 255/75R17
Dead-On is offline
post #12 of 19 Old 12-24-2013, 11:13 AM
RockyClymer
RedRock4Wheeler
I am running 35 inch KM2s and been on for 40k miles.
NRA Life member
post #13 of 19 Old 12-24-2013, 11:20 AM
YATZI1980
2011 JK Wrangler
It's probably the roads terrain and driving style. Also like stated before the rears wear faster because of the traction control. I usually turn off the traction control when offroading. I would rather control wheel spin myself with throttle response.
YATZI1980 is offline
post #14 of 19 Old 12-24-2013, 12:01 PM
RockyClymer
RedRock4Wheeler
YATZI1980 - do you turn the entire system off, or just the ESP? Turning off the ESP still leaves the BLD system in operation...
NRA Life member
post #15 of 19 Old 12-24-2013, 12:09 PM
SoK66
2009 JK Wrangler
My 09 was going through the rears quickly. When I installed Teraflex Big Brakes & M/C I also replaced the rears using Autozone's top of the line pads & rotors. They appeared to be better quality than the stock stuff and less costly. 20k miles plus later the rears look great. Btw, I've also shy off ESP using the steering wheel hokey pokey.
Jeeps: Where my 401(k) went to die!
SoK66 is offline
