New to re-gearing - JeepForum.com
post #1 of 47 Old 03-14-2016, 04:52 PM Thread Starter
Dtperrell
New to re-gearing
So I searched through a couple of threads and couldn't find the information I was really looking for.
I've never done any gear work so I'm very new to all of this but I feel like my 08 2D JK needs to be re-geared for the 35's that are on it. It's pretty sluggish while city driving and when on the highway it never fails to lose speed when taking on hills. Any help would be great, I'm pretty eager to learn about all of this.
2008 JK on 35's
Dtperrell is offline
post #2 of 47 Old 03-14-2016, 05:24 PM
Digger838
So what are some of your question?
And a little more info in your rig goes a long way.
I'm no expert but have learned a lot in the time I've been on here.
So WHEN I regear with my set up ( 3.6, 6speed, 3.21factory gears) I will be getting front and rear e-lockers, 4.56 gears, and some structural support for my Dana 30 from axle.
Digger838 is offline
post #3 of 47 Old 03-14-2016, 05:53 PM Thread Starter
Dtperrell
3.8 v6, 6-speed manual, 35 in tires, 3.5 rough country lift kit, haven't checked the gear ratio yet but I'm fairly sure its stock. I'll try and get some pictures of my front and rear end you probably know how to identify them better than me. I just want to know where I should start if I want to re-gear it for daily driving. I do a little offroading but honestly not enough to need anything crazy. I've seen all kinds of terms thrown around that I don't really understand. I know about the ring and pinion gear and how they work but not much past that.
2008 JK on 35's
post #4 of 47 Old 03-14-2016, 05:56 PM
329892 - Deactivated
Guest
figure what rpm you like and see what matches with this...
2200 is usually pretty nice on the highway.
http://www.grimmjeeper.com/gears.html
329892 - Deactivated is offline
post #5 of 47 Old 03-14-2016, 06:47 PM Thread Starter
Dtperrell
Got some pictures of the rear end and front end.
2008 JK on 35's
post #6 of 47 Old 03-14-2016, 06:54 PM Thread Starter
Dtperrell
This is somewhat embarrassing but I have no idea what transmission and transfer case I have...
2008 JK on 35's
post #7 of 47 Old 03-14-2016, 07:20 PM
Xatten
Somewhere on here or on quadratec's web site are gear charts that will give you what you seek. Do you have an automatic or manual? It makes a difference. You will need 4.88 gears or somewhere around that to make for a much better Jeep.
Just Hunt!
Xatten is offline
post #8 of 47 Old 03-14-2016, 07:47 PM
Digger838
So as of axles, I've herd of 2007's with Dana 35 rear rears and Dana 30 front, all 08+ have a Dana 44 rear, and a Dana 30 front (sport,Sahara, Moab,exc.) Rubicons have both Dana 44 front and rear, options for gears would be 3.21,3.73(that I know of) and 4.10(rubicon)
I can't distinguish by eye the difference cuz I'm not that good haha
You can request a build sheet of your jeep from JEEP using your VIN#
post #9 of 47 Old 03-14-2016, 07:54 PM Thread Starter
Dtperrell
6-speed manual
2008 JK on 35's
post #10 of 47 Old 03-14-2016, 08:25 PM
Digger838
http://www.decodethis.com/blog/6-vin_decoder
It said its a vin decoder I didn't try it maybe someone has or will, I got it from another forum
post #11 of 47 Old 03-15-2016, 07:55 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
NSG370 (close ratio 4.46:1 first gear) transm and NVG231 Transf.
Rubicon uses NVG231 4:1 Transf
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #12 of 47 Old 03-15-2016, 08:10 AM
JIMBOX
ooops !
The Rubi uses the NV241OR (4:1) for the xfer case -
Whatever-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #13 of 47 Old 03-15-2016, 08:26 AM
KrawlOff-Road
Vendor
KrawlOff-Road's Avatar
Use the VIN decoder or just call the dealer. They can run the VIN and see what gears came in there. Sometimes there is a tag on the axle but that is the only way. You can't look at the diff and tell. We need to start there. If you have 3.21's you will need a new carrier in the front. If you don't have a Rubicon, you will have a D30 front and a D44 rear. 3.21's or 3.73's were the most common option. Some years, you could do the towing package and get the 4:10's but none of that really matters as long as you don't have the 3.21's.
Let us know if we can help. We have a gear package with a master install kit (comes with new bearings and all). It is the way to go when doing gears:
http://www.krawloff-road.com/product_p/gearmaster.htm
-Jason
Phone: 864-437-8029
Forum Discount: KORJEEPFORUM
KrawlOff-Road is offline
post #14 of 47 Old 03-15-2016, 10:19 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by JIMBOX View Post
ooops !
Whatever-
JIMBO
oops. brain fart.
post #15 of 47 Old 03-15-2016, 10:24 AM
JIMBOX
Heh Heh, my wife complains about mine--ALL THE TIME !
Wait, were we talking about the brain ?
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
