New pads and rotors??? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > New pads and rotors???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 12-06-2010, 11:27 AM   #16
mtbr
My Yj went 60000 miles before doing anything to the brakes.
And all i did were the pads.....
2012 4 door Sahara / Black
2008 4 door Sahara / Rescue Green Jeep Club Member #15
1992 YJ / White
mtbr is offline   Reply With Quote
Unread 12-06-2010, 01:23 PM   #17
DangFoo
DangFoo's Avatar
I will be replacing my rear set this week and I have 34K miles. I'm getting the wear indicator "squeel" from the rear left and pad looks to be 75% worn.
Miles driven is a variable, but it's also the type of driving you do - I'm in a lot of stop and go (3rd most crowded metro area in USA) and I run a lot of hills on the way to/from Tahoe.
DangFoo is offline   Reply With Quote
Unread 12-06-2010, 03:25 PM   #18
JQJK
I just went to get a oil change at my dealer and they told me I had about 15 to 20% pad left on the rear. 08 Sahara with 32000 on the ticker
Anywho, I told them to hold off replacing them, I would do them myself. What brand of pads do you guys suggest to get? Rotors are good.
JQJK is offline   Reply With Quote
Unread 12-06-2010, 03:31 PM   #19
tavic
2010 JK Wrangler
If you have the automatic, I can see that early pad wear on the rear can easily be caused by the Down Hill Assist. But as for the Hill Start Assist, I don't see how that would cause an issue because it lets go immediately after forward movement is achieved.
tavic is offline   Reply With Quote
Unread 12-06-2010, 03:34 PM   #20
insanitize
Jeepin Old Man
insanitize's Avatar
60,000 and have done the rears twice. The second time I had to replace one caliper and rotor. And my fronts are still on the second set with plenty of meat.
I should say that I've been known to play in mud.
07 Rescue Green Rubicon
AEV hood, AEV snorkel, ARB front bumper with Warn Powerplant winch, Pure Jeep rear bumper with tire carrier, Poly long arm, RR and Poly skids, 35 GY MTR ks, Hutchinson Beadlocks, 4.88 gears
78 Red CJ 7
v8 some mods. lifted
and other assorted old iron
insanitize is offline   Reply With Quote
Unread 12-06-2010, 04:18 PM   #21
rirrgang
What part of Northern Cal are you living?
-Rick
07 Sahara Unlimited
Helping People Create Wealthy Lives @
www.Livesafeandhealthy.net
rirrgang is offline   Reply With Quote
Unread 12-06-2010, 05:02 PM   #22
AlterEgo
24k is about the mileage I replaced mine. I blame the ESP. I've got 49k on it now. The pads are usable, but I'll be buying a set soon. I changed the fronts at about 35k miles.
Gary Greenway - KD8NHC
08 4 Door Rubicon
Member of Two Trackers 4wd Club
Great Lakes Four Wheel Drive Association
United Four Wheel Drive Associations
AlterEgo is offline   Reply With Quote
Unread 12-06-2010, 05:09 PM   #23
saharac
I found out first hand that rear brake pads wear way faster and apparently its quite common with JKs... The dealership wanted to charge 300$ for pads and turning rotors....
When i opened it up myself, the pads were thin but could have easily gone another 8k-10K miles.... anyways replaced the pads since i already bought them, and it cost me abt 50$....
saharac is offline   Reply With Quote
Unread 12-06-2010, 05:21 PM   #24
paul84043
Friggin dealers....
Checker will turn your rotors for 15$, if you even need it...which if you stay up on the pads and don't score them...85% of the time you don't. They want to grind your rotors to nothing so you'll have to buy new ones from them the next time.
paul84043 is offline   Reply With Quote
Unread 12-06-2010, 05:49 PM   #25
DangFoo
DangFoo's Avatar
I'm in the town of Danville, which is North of San Jose and East of Oakland.
Unread 12-06-2010, 05:57 PM   #26
paul84043
Looks like the Jury's pretty much come back on this one, 25k to 35k seems to be average wear. Good to know!
Unread 12-07-2010, 04:32 AM   #27
Green08
Originally Posted by mtbr View Post
I have had my Wrangler jk for only 2 years. Is it normal to
need new "rear" pads and rotors. The front are apparantly
ok. (only 24,000 miles) Dealership....or Stealership?
This happened to my '08 at 30k and another JK I know of at 35k. Fronts were ok as well.
Green08 is offline   Reply With Quote
Unread 12-07-2010, 05:03 AM   #28
JeffinWesternWA
2010 JK Wrangler
Only 24K? geez, you need to review "driving habits", ...my "cars" lately have al gone past 100K miles before pad replacement is needed, usually at 3/32 -1/8"...granted a two ton Jeep may not do that but 24K is way to short of service life...
JeffinWesternWA
JeffinWesternWA is offline   Reply With Quote
Unread 12-07-2010, 05:08 AM   #29
Warlord2
I could of sworn I read somewhere that these rotors are not supposed to be turned. I have no idea why, think I read it in a different thread on this subject and a dealer tech told us.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline   Reply With Quote
Unread 12-07-2010, 05:44 AM   #30
Prot
Gold Member
Prot's Avatar
To the person who suggested a dragging emergency brake, they are dead wrong. The emergency brakes are drum brakes, completely separate from the the normal disk brakes.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, Goodyear Duratrac 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Front Rancho 9000 shocks, Rear Bilstein 5100 series shocks, 5.13 gears, Kenwood DNX9990HD, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
Prot is offline   Reply With Quote
