New JK owner needs help removing doors. - JeepForum.com
post #1 of 35 Old 09-01-2009, 07:17 PM Thread Starter
WKUJK
Hey guys first of all thanks for all the info I have read so far. I am going to take the doors off but my jeep 07 two door, didn't come with a manual. I just need to know is all I need to do to take the doors off unscrew them at the hinges then disconnect the wiring harness? Will a door chime continue to go off with the doors off? Thanks, sorry for the noobie question, I couldn't find an answer when I searched.
WKUJK is offline
post #2 of 35 Old 09-01-2009, 07:24 PM
jeepcrazy93
I the doors off of a 09 Jk about a month ago and it was pretty simple. Do yourself a favor and buy a good set of torx bits b/c you will probably need them down the road. You shouldnt have the door chime problem or at least the jeep I worked on didnt. Just unscrew the torx nut and disconnect the wiring harness. It took me a second to figure out how the wire harness disconnects but it was simple once you figure that out.
93 YJ 4.0 AX-15 33's 8.8 with CJ front clip
03 F-250 Extended Cab Long Bed with 7.3
jeepcrazy93 is offline
post #3 of 35 Old 09-01-2009, 07:25 PM
torpex77
Unscrew the torx bolt at the bottom of the hinges.
ROLL DOWN THE WINDOW. (not necessary, but makes them easier to handle)
Disconnect the wiring harness and unhook the retaining strap from the door.
Open and lift. I think they come off easier if I lift while I rotate them open.
Doug
Silver JK 4-dr Sahara
torpex77 is offline
post #4 of 35 Old 09-01-2009, 07:26 PM
jeep0867
2009 JK Wrangler
Yes....just lower your windows, unscrew the the hinge torx bolt using a T50, unclip the wire harness from each door and lift off and store. Once you disconnect the wire harness there will be no chimes. Now go out and enjoy!
jeep0867 is offline
post #5 of 35 Old 09-01-2009, 07:31 PM Thread Starter
WKUJK
Thanks for the speedy help.
WKUJK is offline
post #6 of 35 Old 09-01-2009, 07:31 PM
HMUSN
exactly like the guys above said. just undo the torx bolts and the harness and they will come right off.
The YJ's are much harder to take off.
Directions:
Pull up.
seriously though.. the torx screws are a good idea.. less doors get stolen that way.
HMUSN is offline
post #7 of 35 Old 09-01-2009, 07:50 PM
ge2
Gold Member
ge2's Avatar
Also-- if you haven't already done it-- be sure to hold your door from swinging, once the strap is off. Otherwise you get a pretty little dent in your hood. I got lucky and read about this before I took my doors off.
ge2 is offline
post #8 of 35 Old 09-01-2009, 09:28 PM
WaldenL
2009 JK Wrangler
I will add that you slide the red clip to release the wiring harness; once done press the lever and the slide right apart. Oh, and don't plug them back in with the car alarm set. I did that the first time, confused the hell out of the computer. Had the pull a fuse to kill the alarm.
WaldenL is offline
post #9 of 35 Old 09-02-2009, 12:49 PM
braincloud
Just put the key in the ignition and turn it on - that will stop the alarm. (Scared the crap out of myself the first time I reconnected the doors with the alarm armed)
braincloud is offline
post #10 of 35 Old 09-02-2009, 01:18 PM
WaldenL
2009 JK Wrangler
You would think so, wouldn't you. Didn't for me. That was the first thing I did. Maybe I undid the door first, I don't recall. Believe me I tried a bunch of things.
WaldenL is offline
post #11 of 35 Old 09-02-2009, 03:01 PM
4x4jkx
You have an alarm? Mine just came with a sticker that said it had one
4x4jkx is offline
post #12 of 35 Old 09-02-2009, 03:18 PM
ge2
Gold Member
ge2's Avatar
I just make a BOOP BEEP sound with my mouth (really loud) as I walk away from the jeep, and point the key at it.
ge2 is offline
post #13 of 35 Old 09-03-2009, 03:08 AM
richnev
2014 JK Wrangler
lmao ok I am adding that to my signature
05 Jeep Wrangler X .... RIP
07 Jeep Wrangler Unlimited X ...... let the build begin
ARMY TEAM MEMBER #4
Originally Posted by her94yj View Post
lets put it a way a kids will relate......its like a hooker.......... SURE a 15 dollar handy from a detroit toothless 60 year old can get it done....... but NO where is it as nice as the $5000 an hour goddess from vegas or hollywood
....... dont be that fat guy on the beach in the speedo you dont want to be "that guy"
richnev is offline
post #14 of 35 Old 09-03-2009, 05:54 AM
Little Green
1991 FSJ Wagoneer
I found that being on the outside reaching through the window and holding the door handle on the inside is the easiest way to pull them off. Also, mine do not come off unless they are angled roughly 45 degress from the jeep.
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #15 of 35 Old 09-03-2009, 10:35 AM
Nuts
2009 JK Wrangler
Haha thats great. I'm dying here at work and people are looking at me like I'm crazy. O well not my fault that they don't get good humor.
Nuts is offline
Removing doors Redrum257 TJ Wrangler Technical Forum 55 04-25-2009 05:20 PM
Removing doors martina113 TJ Wrangler Technical Forum 16 08-05-2008 12:56 PM
Removing Doors BYGJERRY TJ Wrangler Technical Forum 27 04-02-2006 08:45 PM
removing doors sistrunk TJ Wrangler Technical Forum 23 08-25-2005 07:23 PM
Removing doors? thebulkinator TJ Wrangler Technical Forum 26 10-02-2004 08:17 PM
