new jk mygig ? - JeepForum.com
post #1 of 7 Old 02-17-2008, 07:20 PM Thread Starter
whyknot
new jk mygig ?
i picked up my new jeep yesterday and i have a question about trying to upload my ipod onto the HDD. the screen keeps saying it's not reading the device.Also is there any way to install a few songs off a regular C.D. without having to copy the whole disc and then deleting the songs i don't want?Thanks in advance whyknot
whyknot is offline
post #2 of 7 Old 02-17-2008, 07:57 PM
rirrgang
Won't work. You most likely don't have your iPod set in HD mode or in MP3 mode. Do a search here for "ipod mygig" and see what you find. I think the mygig will only read flash drives and not even all of them. I use a Corsair Falsh voyager. Curious to hear about your results.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #3 of 7 Old 02-18-2008, 06:07 PM
Denny2565
Your music files have to be either WMA or MP3. If you copy from the disc, it will copy the entire disc, you can't pick the songs to my knowledge. The best thing to do is put it on a flash drive. That way you can pick the songs and it only takes a few seconds to transfer. I don't like to copy from the disc because sometimes the mygig doesn't recognize the song titles or artists and your left with a bunch of "unknown" songs on the hard disk. And it takes forever to copy too. Also, when you plug in the flash drive, it will ask which files you want to transfer.
Denny2565 is offline
post #4 of 7 Old 02-18-2008, 06:51 PM Thread Starter
whyknot
thanks for the reply guys i'm going to go the flash drive route. thanks again
whyknot is offline
post #5 of 7 Old 02-19-2008, 06:36 AM
amr42
When copying from the flash drive, you only get the choice of which albums/folders to copy. It will copy all of the tracks/files in the folders you select. Once copied you can delete individual tracks/files from the Manage My Music menu option - under playlists.
Hope this helps.
amr42 is offline
post #6 of 7 Old 12-16-2012, 04:17 AM
parvo
2014 WK
When copying from a cd, there is no option to select tracks - you will need to copy the entire cd then delete the songs you don't want.
MYGig - could be better - should be better!
parvo is offline
post #7 of 7 Old 12-16-2012, 01:40 PM
Spank
2014 JK Wrangler
Don't even bother copying it to the HD. Just play it directly off the flash drive. It's easier to navigate because it'll keep your folder structure. Use MP3tag to organize and clean up files.
'14 Wrangler Unlimited Rubicon
Spank is offline
MyGig anyone? cpunter JK Wrangler Technical Forum 1436 12-04-2016 02:01 PM
Mygig mic for REN or Need whole kit? rgt75 JK Wrangler Technical Forum 2 07-16-2009 09:14 AM
MyGig ver. 9.711 Zaphoid JK Wrangler Technical Forum 2 03-12-2008 11:05 PM
MyGig is here plyzie JK Wrangler Technical Forum 7 03-10-2007 09:01 AM
Mygig Bamoman JK Wrangler Technical Forum 0 02-25-2007 08:02 AM
