New JK / MPG & Lift Question - JeepForum.com
post #1 of 8 Old 08-08-2010, 07:31 PM Thread Starter
aermotor
Hey everyone! Picked up a used 2007 JK Sahara Unlimited last week and boy do I love it! It's got (I believe) a Rough Country 6" X-Series lift. I just put new 35" BFG KM2s on her as well. Few questions if I may from you experienced JK guys/gals!
MPG / Performance
I've been reading a lot of posts about the Superchips Flashpaq etc. on improving performance and mpg. Below is what my JK is running with and without OD.
OD OFF
70mph @ 2850rpm in 4th gear
OD ON
70mph @ 2000rpm in 3rd gear (downshifts constantly)
I've read A LOT of people have problems with the tranny shifting up and down all the time when hitting the slightest of inclines with OD ON and I'm having the same issue. So I tried turning OD OFF and you can see what my RPMs are above. It's more more stable and I don't get the constant up and down shifting, but I need to know am I running too high rpm to be getting decent milage, or is that a god range? Do you know what gearing I might have? I'm thinking it's 4.10 but feel it might not be stock.
I don't think I'm getting the correct odometer/mpg readings either because of the 35" tires, I don't think the original owner get it re-calibrated but I can't tell....
Rough Country Lift
I think I have the 4" or 6" X-Series lift but really am not sure and there's no information from the dealer on any of the aftermarket stuff. Can anyone tell by the pics if it's the X-Series or regular? This lift is pretty gigantic so I'm wondering if I can adjust it if it's the X.
Front
Rear
Front
Front
Rear
Anyway, thanks in advance for any help! Just trying to figure out more about what I have hear. I love this beast. Just need to get it tuned to run better.
aermotor is offline
post #2 of 8 Old 08-08-2010, 08:29 PM
McKBrew
JK Wrangler
Not sure what type of lift it is by looking at it, but size wise I am going to guess 4" just by where the tires are sitting in the fenderwells.
Not sure about the gears, but you could contact Chrysler for a build sheet and see what was installed. Another way to tell especially if they are aftermarket gears is by doing what is detailed in this thread.
http://www.jeepforum.com/forum/f96/w...7/#post9832965
The answers to some of your other questions might be here.
http://www.jeepforum.com/forum/f96/j...reads-1074059/
McKBrew is offline
post #3 of 8 Old 08-09-2010, 05:18 PM Thread Starter
aermotor
I looked through most of that and didn't find many answers to my specifics of 3rd gear vs. 4th gear. Not sure if running 2900 in 4th instead of 2000 in 3rd is better for milage.
aermotor is offline
post #4 of 8 Old 08-09-2010, 09:06 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I noticed that it appears the vent tube to your rear differential/axle is hanging down in the last picture you posted...needs to be relocated higher up with the original clip. (It is that rubber tube with the white plastic tip in it).
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 8 Old 08-09-2010, 09:18 PM Thread Starter
aermotor
Ahh yes thank you! I saw that too and wondered what it was, dealer (Chevy) had no clue, bah! It looks like it's snapped off so I'll take a look. It's under Aut Nation warranty and I found some other stuff wrong with it, so if I can't just plug it back in I'll have them fix that.
aermotor is offline
post #6 of 8 Old 08-10-2010, 01:09 AM
asknight
The Superchips will definitely help to some extent in that it will move the trans shift points to where they should be for your tire size, while also correcting your speedometer and odometer, resulting in your dash calculated fuel economy being more accurate.
However, for you to get back to close to stock performance levels with that lift and tires, 5.13 gears are required.
asknight is offline
post #7 of 8 Old 08-10-2010, 08:17 AM
Blu-Jacket
2009 JK Wrangler
If you're not sure about the speedo being accurate, might try comparing it with a portable GPS. If you need to correct it, the AEV Procal and Superchips will do the job.
Blu-Jacket is offline
post #8 of 8 Old 08-10-2010, 08:31 AM
JIMBOX
These guys have it pretty well tagged for your problems and I've looked at this several times--just noticed that--
The brake lines appear to be streched, at "REST", whick means that your first real "Flex"could be areal problem and
The rear brake lines, besides being streched to far, are rubbing against the swaybar and thats DISASTER, along with the strech !!
checkitout !!
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 04:06 PM
Stupid question. Anyone ever fab anything to lift rear bumper after doing 1" lift blackruby56 TJ Wrangler Technical Forum 11 09-11-2009 01:15 PM
body lift or suspension lift, no this isnt a stupid question!! lumpster TJ Wrangler Technical Forum 5 05-11-2009 09:19 PM
Kinda newb lift question-lift springs signal34 TJ Wrangler Technical Forum 2 08-05-2008 07:56 PM
