New brakes making noise - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > New brakes making noise
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits End of Summer Sale, 20% OFF!
Unread 08-09-2014, 07:32 PM   #1
Mudzilla6661
Mudzilla6661's Avatar
2010 JK Wrangler
I just installed new pads and rotors today. I took it for a test drive and a little into the drive I heard a grinding noise. And then in my driveway I stopped quick and heard a clunk. Maybe the caliper moved forward? I know I tightened everything up. Do I need a brake in period?
check out my build of Mudzilla
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline   Reply With Quote
Unread 08-10-2014, 07:44 AM   #2
Mudzilla6661
2010 JK Wrangler
Bump anyone?
I am taking my fronts off right now and re setting the pads again. Thinking I might not have reset the caliper all the way. And making sure all bolts are tight. Then I'll check the back. I am rotating the tire by hand too to make sure no noise is present
Unread 08-10-2014, 02:42 PM   #3
Magatetzz
Did you clean and lubricate the pad slides? (Remove the metal click in shims and clean under them as well, they can build up dirt/dust an corrosion and cause brake drag
... and see what it's really going to take to build one...and then I'm going to triple that cost/time estimate and see how I feel.
Best gas milage from my Jeep to date: The time I pushed it across the lot at work.
Magatetzz is offline   Reply With Quote
Unread 08-10-2014, 04:15 PM   #4
Mudzilla6661
2010 JK Wrangler
I cleaned under them but didn't lube them. They seemed fine. So it's the brake pads not sliding back to away from the rotor? Will this fix itself?
Unread 08-14-2014, 11:15 PM   #5
Magatetzz
The brake pads will wear quicker if they can't be fully released. I recommend cleaning both sides of the anti rattle clips (what the pads sit on) and lubricating the slides, that way when pressure from the caliper is released the pads won't stay applied.
Unread 08-15-2014, 01:14 AM   #6
Mudzilla6661
2010 JK Wrangler
I actually figured it out the other day. Forgot to post back. Basically I had to just adjust my parking brake because that was what was rubbing not the pads.
