New brakes and i have a squeak - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > New brakes and i have a squeak
XJ Rail Sale!The Ruffstuff NOT Universal 4 Link Kit!Vanco Big Brake Kit Promotion!
Unread 10-10-2014, 02:08 PM   #1
Mudzilla6661
Mudzilla6661's Avatar
2010 JK Wrangler
These are brand new ceramic pads and slotted rotors. I have a squeak coming from the front. I greased the slides and put brake parts cleaner on them to try to see if there was just dirt being trapped. It isn't all the time and it doesn't last through entire brake time. I will think its better then it comes back. Any suggestions?
check out my build of Mudzilla
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 03:24 PM   #2
goodwrenchdave
If its a rotating squeak, then you have dirt/corrosion between rotor and hub. Also check that the alignment shims (thin metal shims on the sliders- If it has any are properly fitted). If it's a squeal on application then remove the caliper/pads and clean the corrosion off the caliper "contact" area (where it touches the back of the brake pads) use metal brush,rasp, whatever you fancy; but do it!. I call them the "fingers"
for lack of better term. This area has to have perfect contact with the pad or squeels on (light) brake application will result. Shims and pastes are also available as Aids - but start with the basics of a brake job.
If its more of a raspy grind/squeal all the time- check that the backing plate is not touching/rubbing the rotor
goodwrenchdave is offline   Reply With Quote Quick reply to this message
Unread 10-11-2014, 12:36 PM   #3
jwmbishop
2011 JK Wrangler
If you aren't supervising other techs - your boss is missing a golden opportunity....
J Wm Bishop EA, ASADE
Alcohol - because great stories never run on gasoline...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 06:01 PM   #4
Mudzilla6661
2010 JK Wrangler
I will have to check them again must be some dirt spot I am missing
