New '15 Wranger - "X" Have a question... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > New '15 Wranger - "X" Have a question...
The Boss is away but Erin is here to STAY with a F.Y.S. SaThe Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-06-2015, 04:57 PM   #1
15X
I have a question that might have been answered here a million times, but I need help. It's those rear seat headrests, that are blocking my views. Also, I cannot lower the rear seats flat because those rear seat headrests hit the front seats. So, how do I remove the dang headrests from the rear seat? I've tried; there is no button to pull them out and they won't lift out. I'm a single hot guy and no one will be in those back seats so I want to lower them permanently. Thx.
15X is offline   Reply With Quote Quick reply to this message
Unread 05-06-2015, 05:19 PM   #2
guls
2015 JK Wrangler
My rear seat headrests fold automatically up when I lower them.
guls is offline   Reply With Quote Quick reply to this message
Unread 05-06-2015, 06:14 PM   #3
JayKay12
Texan
JayKay12's Avatar
If it's like the previous years press these in and pull up on the headrest at the same time.
Project F.J
3.6 Pentastar
2.5 Terraflex lift
Bilstein 5100s
35 Cooper STTs
JayKay12 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 06:56 AM   #4
tarditi
2015 JK Wrangler
I'm not sure the rear headrests remove, but they do fold back... make sure the seat release lever is pulled firmly as you fold the seat down... as said, they should "automagically" fold back at that point.
Dustin Tarditi
Raleigh, NC
Departed Jeeps: 1987 MJ, 1993 YJ, 1996 ZJ, 1997 TJ, 2004 Rubi, 2005 WK
tarditi is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 08:39 AM   #5
442Wrangler
In like Flynn.
442Wrangler's Avatar
On an unlimited yes, not on the 2 door real Wrangler . As one poster above stated just push in on the button and pull up, they will come out!
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1998 TJ Sahara Sold
-3.25" RC spring lift, Eagle alloys 125s, 33x12.5x15 Cooper STTs, XRC8 winch with stock bumper mount
1994 YJ SE Sold
-4" RC spring lift, 33x12.5x15 Firestone M/Ts, Eagle alloys 125, and a 4 cylinder to boot
1960 Willys Wagon
-Going to be restored and painted Omaha Orange
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
Male RN Jeep Club #1
442Wrangler is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 09:05 AM   #6
joeydominick
Had issues till I put a 37 on back, no I can't see anything
joeydominick is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 05:24 PM   #7
15X
Thanks for the responses. Mine is a 2dr. I've tried and searched all around the base of those headrests, and there is no button to push in that lifts out the headrests. And when I fold down the seat, the headreasts do no collapse. I am getting ready to take a hack saw to them......
Unread 05-07-2015, 06:48 PM   #8
RAZORBILL
2014 JK Wrangler
Don't do it. Unless you have a one of a kind Jeep there is a sliding button on the base (attached to the seat) that when pushed in will allow you to remove the headrest. It does take a little for effort to remove it after it gets up to it max height. Both buttons are located on the left post base as you look at them from the rear gate.
Previously owned: 80 CJ-5, 97 TJ,99 XJ, 95 YJ,10 JK Rubicon Unlimited, 10 JK Sport
RAZORBILL is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 11:20 AM   #9
CoryB
2015 JK Wrangler
Originally Posted by 15X View Post
<snip> I'm a single hot guy and no one will be in those back seats so I want to lower them permanently. Thx.
Good to see you're modest too.
The headrests are removable in the 2-door but they're tight and the buttons (for lack of a better term) are pretty much flush so they're really difficult to find. I struggled with mine for several minutes each but got them out eventually.
CoryB is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 11:32 AM   #10
Mark27
Did you ever consider just removing the rear seat?
Once you figure out that no actual human can access it, it quickly loses its appeal.
Mark27 is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 11:57 AM   #11
Highway 4x4
The 2 door is a 2 seater. No real full size human can use the back seat and remain sane.
I'm a Jeeper without a Jeep or a winch.
Going to work on changing that.
Highway 4x4 is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 09:19 PM   #12
Reskar
2015 JK Wrangler
I also vote remove the rear seat entirly. Reclaim all that wasted space if no one will ever use them.
Reskar is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 07:11 AM   #13
bartruff1
2014 JK Wrangler
I had the same problem...but if you move the front seats forward as much as possible, the headrests can clear the front seats and you can fold the rear seat down and out of the way without removing or cutting anything
At least on my 2014..
bartruff1 is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 07:36 AM   #14
PatyWagon
2015 JK Wrangler
Being only 5'2" the removal of the headrests was a must when I had both of my JKs. We would remove them and keep under back deck in case we had a passenger in the back and had to put them back on. Alto getting in is difficult I have ridden in that back seat from ks to fl before.
Sent from my DD 2015 FDII PATRIOT using JeepForum
PatyWagon is online now   Reply With Quote Quick reply to this message
Unread 05-10-2015, 01:35 PM   #15
Butterbuddha
Butterbuddha's Avatar
2010 JK Wrangler
There is indeed a little button at the bottom of the headrest post just like the picture JayKay12 posted. Though tossing a 35" on there pretty much eliminates your view anyways. I got a license plate mount for the spare and put in a back up camera.
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline   Reply With Quote Quick reply to this message
