need some terraflex suspension help - JeepForum.com
post #1 of 4 Old 12-07-2012, 04:00 PM Thread Starter
MoreMud
Hi,
I just added a terraflex leveling kit to my JKUR and I'm noticing that when I go over bumps it will pull the steering wheel. I think left up and right the suspension is moving down. It's not drastic but it's definatly noticable.
I tried reaching out to terraflex twice but got no response.
any idea's?
thanks in advance !
-Lovemud
2012 JKU Rubicon
Rugged Ridge Front bumper w/storage ends Rugged Ridge 8500 Winch w/ synthetic rope
PIAA ATP off road lights, full light bar, Terraflex leveling kit, Mygig lockpick
just getting started.....
MoreMud is offline
post #2 of 4 Old 12-07-2012, 05:19 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Need to ask...when you installed the spring spacers (leveling kit) did you properly seat each spring in the spring perch? There is only one way the spring will properly seat...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 4 Old 12-07-2012, 06:39 PM
ncb
Sounds like bumpsteer.
ncb is offline
post #4 of 4 Old 12-07-2012, 07:00 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Or axle steer - as the axle moves up and down it also is moved side to side due to the arc "scribed" by the trackbar. It becomes more noticeable as the ride height is increased. Nature of the Beast and unless it is actually yanking it from you grip - pretty much is what it is. If you notice - even on a stock control arm/trackbar the nose makes a little circular movement as you go over a speed hump - raising makes the circle a bit bigger and more pronounced unless you also raise the track bar mount or use an adjustable track bar to lengthen the link.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
