Need to re-pressurize winter tire air pressure to summer - JeepForum.com
post #1 of 5 Old 05-21-2010, 03:12 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I had been driving 79 mph for eight hours, on my vacation trip to San Antonio from Montgomery, when tire pressure warning light came on. My immediate thought was a tire going flat.
I exited interstate and checked tire pressue. All four tires read 39 lbs. Then I realized the warning light may be warning me of high pressure, so I aired it down to 35 hot pressure.
The only thing I can think was winter cold tire pressure reads much higher at summer temperature, thus the need to repressurize winter/summer time.
2009 JK Rubicon
Shrockworks Mid-width Bumper, Warn 9.5Ti Winch; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - 8/2007
Rubicon - 9/2008
Thunderstrike is offline
post #2 of 5 Old 05-21-2010, 03:15 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Correct. A temperature change of about 8-10 degrees can equal about 1lb or so change in tire pressure.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 5 Old 05-21-2010, 03:24 PM
Colockum
Yeah it happend to me last month (except i did not have a fancy warning system). I was at 43ish psi, hope I did not do too much damage.
Colockum is offline
post #4 of 5 Old 05-21-2010, 03:40 PM
JeffinWesternWA
2010 JK Wrangler
per xysler owners manual 12'F = 1lb on the stock Jeep tires, so check pressures (cold) MORE often in the fall but, at LEAST 2x a month is good practice
JeffinWesternWA
JeffinWesternWA is offline
post #5 of 5 Old 05-22-2010, 06:53 AM
Ron Burgundy
Team CANON
Ron Burgundy's Avatar
2009 JK Wrangler
Good advice gents. Obama would be proud, haha.
I appreciate all of the info & good people on this site.
JK Sahara 2dr
Ron Burgundy is offline
Poll: Is the Wrangler a Summer or Winter vehicle? WCoon Wrangler General Discussion 49 09-13-2009 08:31 PM
Does your jeep serve you better in the summer or winter? rain-gler Wrangler General Discussion 19 02-06-2009 12:03 PM
Winter Tire Pressure dogboy6464 YJ Wrangler Technical Forum 9 12-10-2008 12:08 PM
Summer vs Winter performance Schwalby TJ Wrangler Technical Forum 4 06-12-2007 10:27 AM
Winter tire pressure Varsity Tyler YJ Wrangler Technical Forum 1 01-21-2004 01:23 PM
