Need quick help on bolt size (auto trans skid plate) - JeepForum.com
post #1 of 4 Old 07-13-2013, 02:40 PM Thread Starter
invest2m4
I'm installing a set of LoD sliders on my JK and it uses the stock transmission skid plate bolt where it attaches on the bottom of the frame. I believe it is something like a 7/16. I have a manual transmission, so no stock bolt. Can someone tell me exactly what bolt size/thread it is?? My frame has the nut inside (I assume welded in every frame), so I need the exact bolt size.
invest2m4 is offline
post #2 of 4 Old 07-13-2013, 09:22 PM
TheBoss
Grade 10.5 metric M12 x 1.75 x 45mm. Nice purchase , post up some picts. of those bad boys when you get them on.
TheBoss is offline
post #3 of 4 Old 07-14-2013, 11:21 AM Thread Starter
invest2m4
Thanks! I tried that and it didn't quite fit. Then I realized all I had to do was pull a bolt from the gas tank skid plate. You were close, but the pitch is 1.5 and not 1.75. After a big search, I found some at a hardware store.
I'll post pictures once I get them on. Thanks again!
post #4 of 4 Old 07-14-2013, 08:05 PM
SoK66
2009 JK Wrangler
The JK's skid bolts are M12 x 1.5, a PITA to find. There are very limited head types in that size as well. I've looked everywhere for a set of button heads and have had no luck whatsoever. Poly suggests drilling the holes out and tapping at 1/2 x 20, may be my next move.
SoK66 is offline
