need lift info & regearing info - JeepForum.com
post #1 of 4 Old 01-16-2009, 03:34 PM Thread Starter
stuart2410
I have a 07 X and i need to know how much lift i need to run 35's or 315 and i do some off roading .MY next Question is my jeep is also my daily driver and i have to make weekly 100 mile trip for work Im thinking about going with 4.88 What i need to know is what the rpms are around 70mph give or take and what the gas mileage might be give or take.Any info would helpful thank you.
stuart2410 is offline
post #2 of 4 Old 01-16-2009, 04:03 PM
jk2008jp
lift size
a 3-4 inch lift should give you plenty of room to fit 35's but remember that when you put bigger and wider tires on your fuel goes bye bye a 4 inch lift from rough country is about 500 I dont know if thats what your looking for, cant tell you anything about rpms dont really pay close attention them I just listen to the engine to tell me when to shift.... sorry if thats no help.
jk2008jp is offline
post #3 of 4 Old 01-16-2009, 05:27 PM
Prot
Prot's Avatar
2014 JK Wrangler
Do you have an automatic or manual transmission? You'll want 4.88's if you have a manual and 5.13 if you have the automatic. You need a 3" lift.
I have an automatic 4 door 2007 Sahara, which came with 4.10 gears from the factory.
bone stock with stock 18" wheels and 32" street tires (standard sahara setup) 19 mpg
switched to 17 X 9 wheels and 315/70-17 BFG AT kept stock gearing 12 mpg
regeared the differentials to 5.13 and was surprised at 17 mpg
I have a long list of things I usually include when I answer this question, but I don't feel like doing that right now. If I remember right, I turn 2,400 rpm's at 70 mph. It's been a few weeks since I have been home.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #4 of 4 Old 01-18-2009, 09:28 AM
motoxxx
FYI, I have discovered typically you get more lift than advertised, esp if you are a 2 door. Many of the kits are for 4 and 2 door models generic, so the 2 doors being about 800# lighter get a lot more lift. I did the 3" teraflex and got 5". I replaced with OME 2" and got nearly 3". I luv the OME 2", looks great and ride is plush for a jeep.
motoxxx is offline
Looking to lift my 03 tj - need info oldcrow75 TJ Wrangler Technical Forum 4 11-07-2009 05:51 PM
Looking to buy a YJ... need lift info. GlennH YJ Wrangler Technical Forum 9 07-26-2007 09:54 PM
regearing to 4.56 advice/info needed jeepin man99 TJ Wrangler Technical Forum 12 04-16-2007 09:16 AM
Factory Warranty info? Top info? BlueRidgeRunner TJ Wrangler Technical Forum 5 06-27-2004 03:52 PM
need some info. about a sus. lift supertj4415 TJ Wrangler Technical Forum 9 10-10-2003 10:53 AM
