Need help! Rigid lights wiring into stock fogs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Need help! Rigid lights wiring into stock fogs
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread Yesterday, 05:13 PM   #1
D700
D700's Avatar
2014 JK Wrangler
I bought a set of Rigids Spot lights to replace my stock fog lights on my JKU. Im sure I can wire directly into original light harness or I can just run it into S-Pod.
How have you guys installed this or what do you recommend?
Thank You
D700 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:20 PM   #2
14Sport
2014 JK Wrangler
A lot of guys have had success just wiring into the stock harness. I suggest you try it first by running jumpers from the harness to the lights. If it doesn't work then wire them to the sPod.
2014 JK Sport, auto, 35x12.5x17, 3.73s, BR6 BBK.
I jeep therefore I am.
14Sport is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:26 PM   #3
D700
D700's Avatar
2014 JK Wrangler
Thanks
Unread Yesterday, 08:08 PM   #4
1222
Make mine a Jeep!
1222's Avatar
Yup excellent advice.
Iím one of those that wired directly to the harness without problems. Although they are not rigidís (Baja Designs) they are very similar.
1222 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:50 PM   #5
D700
D700's Avatar
2014 JK Wrangler
I tried directly to harness and when I turned them off they started flickering. I just wired them directly to S-Pod and their great.
Thank You
Unread Yesterday, 09:56 PM   #6
14Sport
2014 JK Wrangler
Thank You
Good deal.
