Need help - intermittant difficult starting - JeepForum.com
post #1 of 4 Old 07-11-2013, 11:17 AM Thread Starter
Bionicrooster
2010 JK Wrangler
so this problem started a few weeks ago and seems to be getting slightly worse. Every so often (1 out of 3 times or so) when I push in the clutch and turn the key, nothing happens. Power is good, radio, lights, all that comes on fine. But doesn't turn over, or even try. If I turn it back off once or twice it will usually start.
I am thinking either the starter is going bad (but would assume I would hear a clicking or something if it was getting power) or there is a solenoid or something that is going bad. Someone even told me there is a little switch down near the peddle that completes the circuit when the clutch is depressed and that can be bypassed / replaced easily. Can anyone give me any pointers on how it is set up and what to look for?
Thanks in advance guys!
" We do not inherit our wildlife from our fathers, we only borrow it from our children."
Bionicrooster is offline
post #2 of 4 Old 07-11-2013, 11:55 AM
lkmn1
Is the light for the sentry key out ?? Or is it flashing
lkmn1 is offline
post #3 of 4 Old 07-11-2013, 12:56 PM
T00THD0C
There is a switch that is activated by pushing in the clutch pedal that lets the starter engage. It's a safety feature to prevent starting in gear. Over time it may have worn out or needs to be adjusted. It can be bypassed but since it's a safety feature I wouldn't do it. Have someone take a look there first. It should be simple to replace or adjust.
T00THD0C is offline
post #4 of 4 Old 07-11-2013, 07:31 PM Thread Starter
Bionicrooster
2010 JK Wrangler
Thanks TD, I think that may be the issue as the cruise control has been finicky lately too and is likely tied into that switch somehow since it is a manual trans. Anyone know where that switch is / what it looks like? I am afraid to take it the dealer and get a 500 bill for a 5 dollar part.
