Need help with door removal.... - JeepForum.com
post #1 of 11 Old 05-31-2013, 05:45 PM Thread Starter
Utah_Jay
07 JKU I can only get the driver door off. The other 3 are stuck really good! I have lifted while rotating back and forth and it doesn't seem to be moving. I can get the entire jeep rocking but the doors won't budge. Are there any tricks to get these things to come off?
WD40? PB Blaster?
2007 JKU Sport
Utah_Jay is offline
post #2 of 11 Old 05-31-2013, 06:02 PM
222Doc
222Doc's Avatar
use wd40 work it. I set up a rope from the roof that can pull the door up. Notthat mine were ever stuck but this would free your hands and then you could use a rubber mallet on the hinge to tap it with?
the doors are heavy and a PITA to R&R all the time. I ended up just getting soft doors and left he hard doors with hard top in a corner to collect dust.
222Doc is online now
post #3 of 11 Old 05-31-2013, 06:02 PM
Godholio
PB Blaster is way better at this than WD40. I'd give it a shot.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #4 of 11 Old 05-31-2013, 06:43 PM
222Doc
222Doc's Avatar
it is but i was thinking it may be hard on the paint too.
post #5 of 11 Old 05-31-2013, 07:10 PM Thread Starter
Utah_Jay
Going to try the PB and let it sit over night. If I don't have any paint left in the morning I will let you know .
When these doors come off I am going to sand the pin to smooth it out and apply grease before the doors go back on. Hopefully that will prevent this in the future.
2007 JKU Sport
Utah_Jay is offline
post #6 of 11 Old 05-31-2013, 07:12 PM
COLOUXJ
2010 JK Wrangler
get a good grip on the door and wiggle it side to side as you pull up. Do this long enough and they will pop out.
COLOUXJ is offline
post #7 of 11 Old 05-31-2013, 09:42 PM
Border
2010 JK Wrangler
I used a jack
it's not me on the video you can do it a bit more elegant using a better tool than the chair
Border is offline
post #8 of 11 Old 05-31-2013, 09:50 PM
COLOUXJ
2010 JK Wrangler
I would not sand the pin. You could make the doors wobble. Just use the technique I posted above and apply grease after you get them off and it will be easier the next time you do it.
COLOUXJ is offline
post #9 of 11 Old 05-31-2013, 11:21 PM
DangFoo
The doors just take 2 people and some wiggling. My hard top and doors stay off all year now; one of the few benefits of living in CA.
DangFoo is offline
post #10 of 11 Old 06-01-2013, 12:27 AM
jbro27
roll your windows down put one and on inside door handle and one hand on the outside. Then get your thighs under the bottom of the door. I yank them out easy this way.
2 door 07 JK
35' Nitto Mud Grapplers
4" Rough Country Suspension Lift
jbro27 is offline
post #11 of 11 Old 06-01-2013, 08:55 AM Thread Starter
Utah_Jay
Thanks for all the tips guys.
I went out this morning and with some work the passenger side doors came off. However the rear driver side door was still stuck. I decided to try the jack trick and it worked great. I jacked up the pin just a bit using an allen wrench to put pressure on it and went back to work. This did the trick.
I am going to use my dremel to clean the pins and the hinges and polish them up before greasing. Hopefully this will prevent this issue in the future.
2007 JKU Sport
Utah_Jay is offline
