Need Help - JeepForum.com
post #1 of 15 Old 08-07-2013, 05:03 PM Thread Starter
AGGIEINFLA
2009 JK Wrangler
Need Help
Started my 2009 wrangler unlimited this afternoon and all the dash lights came on, bells ringing, windshield wipers came on and nothing responds to their switches??? This has never happened before? Thanks for the help.
AGGIEINFLA is offline
post #2 of 15 Old 08-07-2013, 05:59 PM
LVCapo
2015 JK Wrangler
Disconnect the battery for an hour or two. Make sure all the juice is out of the system (Turn the key after disconnecting battery). I've heard the system can kind of freak out once in awhile.
LVCapo is offline
post #3 of 15 Old 08-07-2013, 08:19 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Aggieinfl. How about a thread title that makes sense?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 15 Old 08-08-2013, 04:29 AM Thread Starter
AGGIEINFLA
2009 JK Wrangler
RockyClymer, sorry but what part of NEED HELP did you not understand?
post #5 of 15 Old 08-08-2013, 04:36 AM
Nafpu
2012 KK Liberty
RockyClymer was referring to your lack of specifics. Titling your thread with the actual problem might get you better responses.
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #6 of 15 Old 08-08-2013, 09:18 AM
LVCapo
2015 JK Wrangler
A good thread title also helps others with a similar problem when they use the search feature.
Did you disconnect the battery for awhile and let the system reset?
LVCapo is offline
post #7 of 15 Old 08-08-2013, 10:05 AM
RockyClymer
RedRock4Wheeler
Yes, descriptive thread title, and when you disconnect/reconnect the battery it essentially reboots your ECM and can fix many issues like the ones you describe. It is the first place to start.
NRA Life member
post #8 of 15 Old 08-08-2013, 06:15 PM
Vin
Also it would be a good time to check what condition your battery is in. If it's the original battery, you probably need to change it. The JK computer is super sensitive to drops in voltage. It happens suddenly and it'll seems like you need an exorcist.
Vin is offline
post #9 of 15 Old 08-08-2013, 08:01 PM
SubAtomicGenius
2011 JK Wrangler
He means specifically: do you "NEED HELP" with your Jeep or maybe something else like your hemmorhoids, perhaps. How is anyone to know without opening the thread and reading it?
It's not really clear in the thread title I think. Threads are like books, they need a good title.
For the moderators, perhaps something to that effect needs to be put into the thread rules sticky, I couldn't find any reference to using a good, short, descriptive thread title. In the military we used to call it ABC's - accurate, brief, clear.
SubAtomicGenius is offline
post #10 of 15 Old 08-08-2013, 08:14 PM
LVCapo
2015 JK Wrangler
or for us Americans
Keep
It
Simple
Stupid
LVCapo is offline
post #11 of 15 Old 08-08-2013, 08:22 PM
SubAtomicGenius
2011 JK Wrangler
Capper, you're definitely not included - you're always polite and friendly and ultimately the "voice of reason." I just like a good, detailed thread title, is all.
post #12 of 15 Old 08-09-2013, 05:27 AM Thread Starter
AGGIEINFLA
2009 JK Wrangler
I will work on future titles, jeep is a garage queen its an '09 ~15k miles, new battery 4/2013, I did the battery disconnect and nothing. Took the jeep to the dealer yesterday morning and they kept it overnight. They are not sure YET what the exact issue may be. If you google "jeep unlimited tipm problem" there are many posts with the same symptoms. Thanks for the input. SubAtomicGenius with that screen name surly you knew the post was not about hemorrhoids(correct spelling fyi)
post #13 of 15 Old 08-13-2013, 05:24 PM Thread Starter
AGGIEINFLA
2009 JK Wrangler
The dealer says its the instrument cluster, it is a vin specific part that takes 3-4 days to program and ship. Will keep you posted.
post #14 of 15 Old 08-13-2013, 11:42 PM
Reluctant
I fell for it...When you need help you want everyone to read your post regardless of the title. I can't help though
To truly appreciate Obamacare, you should be not working, undocumented and given it for free.
Reluctant is offline
post #15 of 15 Old 08-14-2013, 12:58 AM
SubAtomicGenius
2011 JK Wrangler
...Thanks for being a good sport...
SubAtomicGenius has nothing to do with being omnipotent...
@ 1:38
